Experiencing an issue with the throttle cable on my 390 cu in with 2 bbl Holley. Cable seems to hang up occassionaly causing the motor to idle high. With a quick tap on the gas pedal, it releases and the idle slows down. Most likely it is the original cable and probably dry inside the cable casing. Don't think its the throttle return spring.
Is it possible to shoot it with a spray lube in the cable case? Am I better off replacing the cable? BTW this is in a '65F100.
you might just get lucky with lubrication but will probably need to get another one. The repro cable just became available in the last few years so you are fortunate there.
Thanks for the replies. The cable connects to the linkage the same as it connected to the AutoLite 2100. After closer examination of the cable, looks like all in all I'll be better off with a new one and be done with it.
