Re-read Tom thread about X code with top over load B. I didn't buy the B code with top over load.
Need to re-read all posts about mild lift again
Perhaps you could post to see if anyone has theirs left over as many have gotten the springs that require that to be remove in order to install the b-codes.
VQT, I did my X code spring mod as an experiment to increase ride height and spring rate, I wasn't sure how I would like it as I had never tried the stock X codes first. Now that is done I will be keeping the mod, I really like the firm but not harsh ride, feels like a truck! The B overloads I used gave me about another inch over what all of my notes say the X's should give a V-10. If you are looking for the extra lift as well as a stiffer spring pack then an overload spring leaf should be what you want. If you are happy with the ride and rate of your new V codes and are only looking for that little bit extra lift then I would look at a leveling kit like Sean's, you should be able to remove a few sections to get the amount of lift you want. You'll just have to get a properly sized center bolt and maybe U-bolts, maybe not....depends how much threaded area they have, you can trim off any excess length after you have then installed. My EX rides with a good deal of rake when running solo and I am contemplating making up a mini level pack to add to the front to help take away some of that rake. I am thinking about cutting my old stock EX front springs down to short sections like Sean's pack, only with two sections per side, maybe worth another inch or so. I already have a set of new longer U-bolts and the old springs so it will only cost me some time, and I'm goint to be swapping out front axle housings soon so it will be just another step while I'm in there.
I hope this helps some.
I threw away all the old Ex springs excepted the bottom leafs of the original Ex rear. I remember reading someone used the bottom leaf of the Ex, cut it to lenght and use it like sean has for the front springs. I thought it was sean, turn out sean bought a kit.
I like the ride of the V now, and maybe the X code give an extra lift that I like to have as oppose to the V. Since money already spent on the V, I just contemplate on how to get the front up just a hair more. Couple of extra cut up rear leaf might be the ticket, Just need to find someone who can cut the leaf. Currently the rear has Mod B and 3.5" taper blocks, it has a rake that Stewart said I'll be like the Bee Stink driving down the road. I like the current rear height so just looking to lift the front a little more. I could take the 3.5" rear blocks out and put back the 2.25" original Ex rear blocks, and I don't want to go lower yet
