Should I buy an 07 6.0 PD
Alright I currently own a 2010 jeep wrangler with a ton of mods and only 13k miles. I have found a nice 2007 f250 crew cab with 57k miles. The truck has an 8 inch lift, 37x13.5x20 toyo m/ts, and he recently threw on a chip last week. I have heard there have been problems with the 6.0s and do not know much about diesel trucks. The truck looks great inside and out. I just do not have the funds to fall in to a diesel truck with a lot of problems due to the maintenance costs. Any help would be appreciated.
Trevor
Trevor
Run away. A tuned 6.0 and an 8 inch lift would make me do a full 180* spin.
Find yourself a nice stock 6.0 with all service records and do whatever you want to it.
Also go visit the 6.0 section and read up on the 6.0's. It is an engine that wants to be maintained.
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
there is a tech folder. There are some very good things
to read about the 6.0 Some Do and Do Nots.
Read the info and then post you questions and someone will help.
One thing to look for is one that has been maintained and it's always
to see the records if you can. One more thing is get a SGII ScanGaugeII : Linear Logic - Home of the ScanGauge
to take on the test drive. Try to do the test drive with a
truck that has sat over night and is cold then your going to want
to go for about a 2 hour test drive and do a hot engine start and
see how it does.
I think is you search for buying a used 6.0L you should find some good
things to look for.
Sean
NOTE : On lifted trucks does not mater if it a diesel or what ever. Your going to
looking at a lot of stress to the front end. The engine may be %100 and the front end hosed.
$3k-ish in parts to do it correctly yourself, potentially a few $k for replacement heads if they're really warped or cracked, your time, tools if you don't have some of the odd ones. Figure in 20-40 hours of time at shop rate if you get it done, at a dealer/real shop and not the shadetree oil dumper on the corner.
Trevor
Trevor
H1449-6
10-26-2008 12:46 PM
