300-Six very hard on gas - Code 327
Alright guys so I finally got around to checking my codes of why my check engine light is often on in my '94 F150.
Only 1 code, 327 witch is EGR Low Input Signal?
What exactly does that mean? EGR valve bad, or wiring/connecting issue?
I wanna get this fixed soon, cause 10-12mpg in a 5 speed 300, 3.08 on stock tires is pretty sad.... and plus I only cruise around 55mph on the highway, witch is the most driving I do, is on the highway.
The DPFE arrived in '96 with OBD2, so he's got the older style EVP. I would start by making sure it's connected electrically. But regardless, even if the EGR is totally non-functional, it's not the cause of your bad fuel mileage. I've eliminated the EGR functional entirely, and I get fuel mileage ~50% better than what you're getting.
Have you checked your PCM to make sure you haven't got leaky capacitors? My guess is that you do, and depending on how badly they're failing, you can get all sorts of unpredictable results.
Blue Rebel
03-08-2012 10:45 AM
fordman16b
03-11-2007 02:34 PM
