OBD2 error codes
Old May 3, 2004 | 10:31 AM
zippy564's Avatar
zippy564
OBD2 error codes
I have a 96 Explorer and I have a check engine light on with a P0471 (I think), it is a exhaust gas recirculation flow insufficient error code. I changed the EGR valve and within 2 miles of driving it, the check engine light was back on. Does anybody know what the next part is that I can change to get this light to go out?
Old May 3, 2004 | 12:49 PM
AlfredB1979's Avatar
AlfredB1979
Did you get a scanner out (or pull the ECM fuse in the underhood relay box for 20 min) and clear the code?
Or did you guess at the code and think EGR valve only? IIRC, that code *could* also mean to check out that DPFE sensor that is known to clog itself up....and flash EGR codes.
Old May 3, 2004 | 06:41 PM
zippy564's Avatar
zippy564
Arrow
Albert,
I borrowed a OBD2 reader and got the code and then cleared it. It was a code for the EGR valve flow insufficient, so I changed the EGR valve. I was wondering what the next part is to change after the EGR valve.
Old May 3, 2004 | 06:43 PM
JerNla's Avatar
JerNla
Well my light came on with that exact code and it turned out to be my Sensor not the valve the sensor was about 89.00 and labor was 66.00. I hope this helps.
P.S. Look at my post on "EGR help!" I believe it will be rite under this one !!
Old May 3, 2004 | 08:10 PM
zippy564's Avatar
zippy564
Jernla,
Thanks for the reply but what sensor are you referring to?
Old May 3, 2004 | 08:17 PM
Fordtech1's Avatar
Fordtech1
DPFE sensor. Box with two hoses coming from exhaust and an electrical connector. Part # on box should be 9J460
Old May 4, 2004 | 08:47 AM
zippy564's Avatar
zippy564
Thanks for the help, I will try the sensor and see if that fixes the problem.
buylow12
Mar 31, 2017 08:36 AM
edman1000
Oct 14, 2016 01:36 PM
awojtowicz
Mar 30, 2016 07:00 AM
jchandler11
1997 - 2003 F150
37
Sep 14, 2015 08:34 AM
Wakeboarder141
2004 - 2008 F150
Feb 6, 2015 03:59 PM
