No voltage at IAC
Old Jan 24, 2013 | 02:43 PM
RIKIL's Avatar
RIKIL
No voltage at IAC
I think this is bad because the IAC goes directly to the PCM. I tested the connector for voltage, not much. Just a few mv.
The PCM is an A9L from my mass air conversion but should work the same as stock PCM.
Is my PCM bad if this happens? I've heard of certain parts of the PCM going bad and not throwing codes.
Old Jan 24, 2013 | 02:57 PM
rla2005's Avatar
rla2005
The IAC and other solenoids (and injectors) receive +12 volts whenever the key is in the Start/Run position via the EEC relay. The IAC receives this voltage on the red wire. The PCM controls the return side by momentarily completing the electrical path to ground.
Check your wiring. Use this as a reference:
bunruh
Nov 1, 2013 06:24 PM
EXP2003
Jan 9, 2009 10:26 AM
ford_nut
Modular V8 (4.6L, 5.4L)
Apr 27, 2008 08:37 AM
96_4wdr
Aerostar
Oct 12, 2005 11:30 PM
messy
Sep 17, 2003 08:35 PM
