C6 vs. AOD
Old Jan 15, 2013 | 06:11 PM
happycruzer's Avatar
happycruzer
C6 vs. AOD
I currently have a '56 ford crewcab 3 door Cabover with a 1980 460/C6 combination mounted on a 1980 E-350 motor home frame. I also have a wrecked '88 ford F-450 with fuel inj. 460 and AOD. My question is, what kinds of problems would I have replacing the C6 with the AOD to achieve a better top speed. I considered replacing entire engine tranny package but I'm not sure of horsepower of F. I. package. Also fuel milage. Early 460 gets about 7 MPG with 4.10 rear gears. I use this truck to pull my 28' toyhauler and car trailer. COE weighs aprox. 7000 pounds empty. Existing 460 has a mild repower.
Old Jan 15, 2013 | 09:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's not an AOD. It is an E4OD. There is a BIG difference between the two.
If you keep the current engine you'll need a controller to operate the trans. It's electronic. Without the controller the trans will only operate in reverse and 4th gear.
If you swap the entire powertrain you'll need to also swap in the complete wiring harness and computer. You might also need to change the rear axle to one with a speed sensor.
Finally, are you certain the '88 is an overdrive transmission? I thought only the diesel had the overdrive in '88, but that was a long time ago and my memory could be faulty. If it is an overdrive trans there will be a wiring harness that plugs into the trans on the passenger's side. Non-overdrive (C6) doesn't have this.
Old Jan 16, 2013 | 12:25 AM
happycruzer
I'll look tommorrow. Thanks
Old Jan 16, 2013 | 12:49 AM
85e150's Avatar
85e150
A quick look here may help with the ID:
https://www.ford-trucks.com/user_gal...id=169485&.jpg=
Old Jan 16, 2013 | 03:27 AM
happycruzer
Smile
Thanks. this will come in handy
GaryLP
Sep 27, 2014 05:46 AM
SuperCruiser78
Jan 27, 2014 03:34 PM
drumfield
Mar 21, 2010 02:03 AM
1ford1
Aug 9, 2006 08:42 AM
fine69
Dec 22, 2003 10:50 PM
