1978 F-150 460, Can I swap the C6 for an AOD?
Greetings fellow enthusiasts. Just joined today, so please pardon the "noobishness" of my first post.
I have a '78 F-150, A-code 460, C6 auto, 2WD, single cab, long bed, etc. Been sitting in the weeds for 11 years.
I've been doing a lot of research on rebuilding the 460, but transmissions aren't my specialty. Does anyone know what is involved in swapping the C6 for an AOD, or if it's even possible?
Engine is still all stock, with the exception of the conversion to run on propane the last 10+ years of its life. 305,000 miles when it burnt rod and/or main bearings.
Any info/tips/tricks would be greatly appreciated.
As far as I am aware the C6 and AOD trannies are not the same length. You would need to shorten the driveshaft and have it balanced. I do not think that the cross member can be re-used for the AOD trans later year 460's used. Then you also have the headache of wiring things up.
It CAN be done, with the proper amount of work and cash.
LoL.! This is just gonna be a hot rod/show truck project, but this is exactly why I was gonna go with a box Chevy, big block stroker and a 700R.. Everything is interchangeable.! Then my grandfather (the truck's actual owner) offered to let me fix up this old Ford that might as well have been mine anyway. Had to start my research all over again because almost nothing can be swapped from one set up to another. Don't get me wrong, I love my old Ford, but HOLY CRAP.! LoL.! Thanks a lot to all of you, though. I'll keep an eye on this in case something else comes up.
JB78f150
18
06-17-2020 12:02 AM
highp90town
09-06-2004 11:13 AM
