Jake's '84 Stepside build thread.
Old Jan 6, 2013 | 09:52 PM
Gary Lewis's Avatar
Gary Lewis
Lots more sunshine here. Less snow and rain. Wide open roads with less traffic, unlike Highway 30 - yuk! But, very little historical significance. Nothing like Gettysburg to see. No going on a day trip to NYC, Philly, or DC. But, Okiehoma is home sorta, and we like it.
Old Jan 6, 2013 | 09:55 PM
GotFord83's Avatar
GotFord83
Love the work....truck is looking great cant wait to see what else you have in store for it
Old Jan 6, 2013 | 10:04 PM
Jake in PA's Avatar
Jake in PA
Sounds like I'd like it! Too cold up here right now. And yeah, Wide open roads ain't something I see here. Except when I go up state to the cabin.
Old Jan 6, 2013 | 10:14 PM
JayzDaddy's Avatar
JayzDaddy
Ok i need a favor Jake. Tell me about those round lights behind the grill and snap a pic or two of how they are mounted. That looks pretty cool. How well did they throw light??
Jake in PA's Avatar
Jake in PA
Thanks man!
Old Jan 6, 2013 | 10:15 PM
JayzDaddy's Avatar
JayzDaddy
Ohhh yeah. The color... I really really like it.
Old Jan 6, 2013 | 10:27 PM
Jake in PA's Avatar
Jake in PA
Yeah no problem. The round lights are a pair of Hella's. I forget the wattage, I'll check and take a pic tomorow. As for mounting, I just positioned the lights upside down and drilled through the metal on top of it. As for light, they are bright! The light is aimed pretty high, but i like it like that because I put fogs on the bumper aiming low
Old Jan 6, 2013 | 10:29 PM
Jake in PA's Avatar
Jake in PA
Dodge color on a Ford
Old Jan 6, 2013 | 10:54 PM
JayzDaddy's Avatar
JayzDaddy
I mounted fogs on the bottom row of my grill. I like a ton of light when im back in my homeplace. The county is so small there is not 1 stoplight in the county. Miles n miles of wooded hardtop. Its DARK ridin those roads at night. I have been thinking for 6 months how to mount offroaders on the front without building a bumper piece.
I must say seeing your current status and picturing the finished product.... I will need a drool rag. Im so jealous of that truck.
Old Jan 7, 2013 | 12:29 AM
siloketh's Avatar
siloketh
Subscribed. Love the blue paint and all.the work you've done. Keep up the good work!
Old Jan 7, 2013 | 11:16 AM
nikmish's Avatar
nikmish
Subscribed, want to see the progress.
I'm on the same boat right now, see my sig...
Old Jan 7, 2013 | 07:54 PM
Jake in PA's Avatar
Jake in PA
Thanks man! This truck is my pride and joy right now, so I'm taking my time doing it right. I totally know what you mean driving through the sticks at night. IT SUCKS when you're lights aren't bright. So I got your pics today. Lights could've been straigher, but you don't notice it with the grille on. Bolts directly above.
Old Jan 7, 2013 | 08:01 PM
  #28
Jake in PA's Avatar
Jake in PA
Thanks man!
Old Jan 7, 2013 | 08:02 PM
  #29
Jake in PA's Avatar
Jake in PA
Thanks! I'm digging your truck too. Doing some good work, keep it up!
Old Jan 7, 2013 | 08:30 PM
  #30
Jake in PA's Avatar
Jake in PA
Got a couple more things done today: Finished up the insulation under the hood. Got a big piece leftover that I'll use behind my door panels too.
Then I started to wetsand my door a little. You can see the patch I did on the bottom of the door. Still a little more work to do though. Quit half way down.
Still have to lay some glaze over this corner and work the bottom but, it's there. Body lines match up perfectly
On the frame, all the old under coat was nasty and bubbling and that's not what you want to see when you look under when it's done. About 2 weeks ago, I covered all the existing under coat with ATF fluid, which makes it soft and gooey. Plus, on the inner frame rails there was no under coat at all too. Put it on the lift, closed the door openings, and cranked the pressure washer up on steam mode. There was pieces of under coat, rust, and who knows what flying all over at me. Works really, really well! And it's not as messy as you think though. Lay 2 air hoses down on opposite sides, so the water is (mostly) contained.
Result:
