injector o rings ?
Evacuating the HPOP reservoir won't do any good before pulling the injectors. You can pull the back two injectors first and let most of the oil and fuel drain in them, but you're still going to get fluid in every hole. Just be sure to evacuate the cylinders before it's all buttoned back up. And don't leave an extra copper washer in the bottom of an injector cup.
Just a fair warning:
If your current injectors have 200,000+ or are approaching that mileage within a few ten thousand, don't waste your time just changing the o-rings or you'll be back in there again soon just doing an entire injector job due to worn poppets.
If you don't know the symptoms of worn poppets, they include:
- Missing on cold starts
- White (fuel) smoke until warm
- Rough running and no power until warm
- Hard starts (even when plugged in and with functioning glow plugs)
I do believe tuning has a lot to do with injector life. The trucks with tuning seem to need injectors closer to the 200k mark than the stock trucks do.
Then again, I've seen stock injectors fail in less than 100k, so sometimes it's just a roll of the dice.
roadbike21
10-27-2006 05:52 PM
