Getting ready to do head gaskets & studs and going to replace all my injectors while I'm in there. Do all the needed o-rings come with the injectors? I ordered motorcraft injectors from Tousley and it looks like they have two o-rings unstalled on the injectors. Parts guy said they come with necessary o-rings, but I want to make sure before I get in there. Thanks in advance for your help.
why replace all injectors? are they all bad? have you checked the ficm for correct voltage to the injectors? the o ring sets from ford are about 5 bucks each iirc. you have any codes that would lead you to replace ALL injectors?? I dont believe i have ever read on here that all injectors were bad. most likely the injector is not the root cause of an issue
IMO, your doing the right thing. I always try to replace injectors in a set. Well I shouldn't say always. Just depends on the situation, but most of the time I recomend doing all 8 at once.
How many miles are on your current injectors? They were designed to go 250,000 miles. I would get some sort of fuel pressure monitoring solution and do the fuel pressure regulator blue spring upgrade.
Thanks for thre replies. Its one of those things where I was pretty sure I was right, but wanted to put my mind at ease.
I have 170,000 on the truck, monitor fuel pressure, have the blue spring upgrade, FICM voltage is fine and have two bad injectors with a third showing signs of going out. I see no reason not to go ahead and replace the all the injectors while I am in there. I really don't want to have to tear into this engine again for a while if I can help it.
