Injector o-rings
Old Apr 30, 2012 | 09:56 AM
carrcreekcaller's Avatar
carrcreekcaller
Injector o-rings
Do most of you just replace the outer 2 injector o-rings when they blow out, or replace the whole injector?
I'm at 190,000 miles and don't drive it much. Truck always ran fine, but started losing oil and then wouldn't start one day. Put a frx on it and rebuilt the fuel bowl. Truck started and blew tons of blue smoke out. Checked the fuel bowl to see if it was still leaking air and ohhh man was the fuel black. My mechanic has pulled the injectors and found 3 o-rings on the AD injectors gone. Visual inspection of the injector tips looks good. Just seems like a lot of $ to spend on injectors if all it needs is 2 outer o-rings, or am I getting the miles where it should be done anyway? Can just the o-rings even be purchased?
ccc
Old Apr 30, 2012 | 10:04 AM
carrcreekcaller
Replacement O-rings for Ford Diesel Engines
Looks like they are available, what's your opinions?
ccc
Old Apr 30, 2012 | 10:45 AM
PaysonPSD's Avatar
PaysonPSD
Replace all the o-rings and the copper sealing gasket on all 8 injectors.
Old Apr 30, 2012 | 10:55 AM
carrcreekcaller
Just ordered them, thanks Payson. Ordered a few extras incase we break a backing ring putting them in.
ccc
IDI-Charlie
23
Oct 28, 2020 08:14 AM
ConvertedFord
Sep 18, 2012 09:26 AM
JT250
Sep 11, 2012 01:42 PM
JamesHajek
Oct 19, 2010 12:34 AM
ecsmith0624
1978 - 1996 Big Bronco
Nov 21, 2003 07:51 PM
