flathead flywheel thickness ?
Old Jan 4, 2013 | 11:12 AM
chriscris's Avatar
chriscris
My block just went to the hot tank (milestone), so I am going through the rest of the parts.
I have 3 flywheels, but dont really know which one to use. They all look ok, but I wanted to use the one with the most 'meat'.
The service manual wasnt much help.
Would anyone know a spec. measurement or any way to tell other than a visual?
Thanks
Chris
Old Jan 4, 2013 | 03:54 PM
jimprowse's Avatar
jimprowse
flywheel spec's
Chris , i think if you get ahold of an "older" automotive machine shop/machinist , they have/had spec books for stuff like that ,
fellow i use here in London is Greg Churcher , Horton Machine , 519 642 4133,, lv a message if he's not there and he'l call you back , mention my name for a good seat !!!.......... Jim Prowse,,,,,,
Old Jan 6, 2013 | 06:31 AM
chriscris's Avatar
chriscris
Thanks Jim
The shop I have my block at has a racing history with Flatheads, so I'll take the 3 flywheels to them to decide.
Chris
Old Jan 6, 2013 | 10:04 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Please post the spec if the shop has one. My flywheel has been cut a couple of times thru the years, and at some point you're supposed to shim between the crank and the flywheel, but I don't know what the break point is.
It has been stated on the Flathead Forum many times that it is critically important to re-countersink the PP bolt holes, because the bolts have a shoulder that sits inside the holes. If you cut enough and don't deepen the countersink, you can start a crack or be unable to completely tighten the PP. Bad juju either way.
Old Jan 6, 2013 | 11:02 AM
oldmerc's Avatar
oldmerc
oldmerc
So that explains those shims between my flywheel and crank.
Old Jan 6, 2013 | 12:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The shims put the PP back against the throwout bearing, so it doesn't go over-center. I'm curious how thick your shims are? Factory-made?
Old Jan 6, 2013 | 12:13 PM
52 Merc's Avatar
52 Merc
I suppose the next question would be how far can you shim the flywheel back before you run into starter engagement and/or jamming issues? Shimming moves the ring gear back from spec.
Old Jan 6, 2013 | 12:26 PM
chriscris's Avatar
chriscris
All 3 of the engines I dissasembeled had the shims.
One flywheel still had a 'raised' portion where the clutch disc engages. My thinking is it has never been resurfaced.
Will update..................
Old Jan 6, 2013 | 01:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Chris, that's a new one on me. I'm certain factory was dead flat. Got a picture? See the pic below; one on the left is a 59-series flywheel, WILL NOT work on a 8BA (for other reasons, on the backside). Is that the lip you were talking about?
Wayne, the typical surfacing removes .010" - .015" so the shims are not that thick. I'm thinking .030", but there's nothing showing in the parts CD.
Old Jan 6, 2013 | 04:28 PM
chriscris's Avatar
chriscris
Actually I meant the surface the clutch disc contacts. It is raised ever so slightly.
I'll do my best to get some pics tomorrow
update - Jan 7th -
No spec as of yet, but here are some pics of what I have (arrow showing slight raised area)
My bad on the shims. I was mixed up with the plate that goes between the flywheel and the bolts.
ddiaz12
Dec 22, 2015 09:06 PM
dylansf23
Apr 25, 2015 07:23 PM
JohnS49
Apr 16, 2013 05:25 AM
Power_age
Dec 14, 2004 02:31 PM
tcoates
Nov 8, 2004 05:15 PM
