Cracked flywheel with flathead c4
Old Apr 15, 2013 | 01:55 PM
JohnS49's Avatar
JohnS49
I have a c4 hooked up to my flathead using a speedway adaptor kit . After about 2 years of driving the flywheel cracked . Contacted speedway and got a new flywheel . They said this was unusual and provided the new fly wheel at cost . Now after about 3 months of driving I belive this flywheel has cracked also . Will know for sure when we get into it . I don't think this is the result of a faulty product . Something is causing this but I don't know what .The mechanic shop I use is local, been in business many years , and I trust . Has anyone had this problem ? Or have any ideas on the cause .
Old Apr 15, 2013 | 03:58 PM
52 Merc's Avatar
52 Merc
Where is it cracking at? Between bolt holes? Somewhere else?
Old Apr 15, 2013 | 04:34 PM
JohnS49's Avatar
JohnS49
As I recall the crack on the last one was on the inner part of the flywheel between bolt holes . We havn't got this one apart yet to check .
Old Apr 15, 2013 | 06:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That sounds like the adapter isn't centered properly, i.e., the t.c. centerline is offset from the engine centerline. That causes the flex plate to flex far more than it is designed for.
Old Apr 15, 2013 | 06:38 PM
4tl8ford's Avatar
4tl8ford
There should be offset pins on the bellhousing
Old Apr 15, 2013 | 10:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You mean in the adapter?
Old Apr 16, 2013 | 05:25 AM
big job's Avatar
big job
You got some flexing going on. Something not concentric-- break out the
dividers micrometers and dial indicators. How is the converter seal
holding up??
junkyarddog82
Feb 12, 2008 09:53 PM
Chumbucket
Dec 7, 2006 04:39 AM
tnystuen
Jul 31, 2006 10:29 PM
rosentr
Feb 21, 2003 10:35 AM
