pulling the bed off
Old Jan 4, 2013 | 08:27 AM
rustywheel68's Avatar
rustywheel68
pulling the bed off
this bed on my 65 is rough. PO welded new 3" metal strips in the very front, and the rear.
everything in between is pretty rough, some places with holes all the way through.
my plan for saturday: buy a case of beer, and have the crew come over to help lift it off, and flip it upside down.
that should allow me to cut off the rusted-out metal supports on the bottom. they will be replaced with 1" square tubing from Home Depot, which is 1/16" thick (that's the thickest they have).
the whole bottom side will get the POR-15 treatment, and it'll get flipped back over.
the topside will get a 4'x8' sheet of 1/16" diamondplate. i'll also get the smaller sections cut to cover the areas fore and aft of the wheel wells. that will get bolted down through the original bed holes, through the 1/16" tubing, down to the frame.
anybody see any holes in this plan? i don't have the welding chops that would be needed to dissect this thing and then weld it back together. i figure that bolting the diamondplate through the original holes will sandwich the rusted-out original bed floor to the frame, and make things "solid enough" (i won't be using this truck for major hauling).
ideas appreciated- thanks
Old Jan 4, 2013 | 12:45 PM
markzieglerinsd's Avatar
markzieglerinsd
if your floor is that rusted out and you are going to put the diamond plate in anyway, cut the old floor out. If you are already cutting the front crossmember out I would cut out the floor.
Old Jan 4, 2013 | 12:53 PM
daveengelson's Avatar
daveengelson
I am going to have to do same on 65 lwb and bookmarked a very old thread Bill posted as a reference. Not sure if any help but perhaps food for thought. Bookmarked couple other threads where member(s) posted pic's of projects involving replacing floor pan's, cab mounts, etc., found they come in handy.
1966 Ford F100 4x2 - 66 F100
Old Jan 4, 2013 | 01:18 PM
rustywheel68
thanks for the input guys- it looks like i was thinking about this the wrong way.
i was assuming that the bed floor was welded to the crossmembers.
but after looking at Bill's pics- it seems that i could cut the floor out, while leaving the crossmembers in place?
i didn't realize that would be possible- the pics were small, but i guess i would just cut about 1" away from the bed wall?
Old Jan 4, 2013 | 01:52 PM
daveengelson
Looking at Bill's link it appears the bed is seperate from the crossmembers, pehaps member familty with removal will chime in?
https://www.ford-trucks.com/user_gal...164970&width=0
In the event I want to contact the author of the thread I usually note their signature; unfortunately, in this case, I did not. It's an old thread and used FTE search and only 'Bill Williams' from Ak, last thread was in 04, so does'nt appear he will be a source. Came across simular project and appears the link is active so able to submit comments, if any questions don't believe he would object?
1964 Ford F100 4x4 - 1964 F100 4x4 GARAGE QUEEN
Old Jan 4, 2013 | 06:10 PM
rogue40's Avatar
rogue40
If you are bent on using aluminum in the bed the best way I know of is to glue it to the steel with body epoxy. Body shops use it regularly now that the newer cars have such thin material.
Old Jan 4, 2013 | 07:52 PM
daveengelson
I was supprised to find used, in very good condition, diamond plate, or plain sheet of metal at the local metal recycle yard at a reasonalbe price. Found this out by calling a couple recycle centers.
Old Jan 4, 2013 | 08:55 PM
jowilker's Avatar
jowilker
Rusty, You should be able to get the bed off & upside down by yourself. You don't need a crew for that.
John
Old Jan 5, 2013 | 07:13 PM
rustywheel68
John
you must have some tricks up your sleeve that i don't know about.
Old Jan 6, 2013 | 12:48 AM
Faber's Avatar
Faber
https://www.ford-trucks.com/forums/821398-bed-off.html
Old Jan 6, 2013 | 08:55 AM
rustywheel68
ah, gotcha...
i started out with that method, but when the first hook went flying by, i stopped.
it was my fault, though- i didn't use heavy enough hardware for the back straps.
the crew came over- the bed is off. now i can finally get a really good look at the huge crack in the frame.
Old Jan 6, 2013 | 09:48 AM
jowilker's Avatar
jowilker
I would work it off the truck stand it on end and walk it to where I wanted to rest it. It does not damage the metal. If you are concerned about the paint you would move it on a moving pad or the like. My guess a long bed probably weighs in the 2-250 lb range. It is large but not that heavy.
John
Old Jan 6, 2013 | 08:24 PM
Faber's Avatar
Faber
ah, gotcha...
Glad you got er : )
Martin Torres
Dec 14, 2017 11:32 AM
rsh1966
16
Nov 24, 2017 05:47 PM
smallello
26
Mar 25, 2016 11:54 PM
49f1
36
Jan 13, 2012 03:30 PM
Riderman
37
Sep 12, 2009 11:39 PM
