Holley 1904 problems
Old Jan 5, 2013 | 09:43 PM
tyrantsparky's Avatar
tyrantsparky
I have a '62 f100 and just purchased a Holley 1904 and am having a hard time connecting it because I think I have the same set up and am missing the same part. If any one has pictures of how this is supposed to look when it's done, and could suggest where I might find this part in Phoenix, it would be much appreciated.
Old Jan 5, 2013 | 10:25 PM
tyrantsparky
I mistakenly added this to the wrong forum, in response to a previous post. Therefore, it is lacking some info. My accelerator linkage does not seem to line up well with the Holley 1904 I installed. It seems that I am missing another piece to make the final connection. Desperate for some great advice and knowledge sharing from those that are familiar. Pictures of the final assembly would also be helpful. Thanks and I look forward to getting my beautiful baby running again.
Old Jan 6, 2013 | 08:54 AM
tinman52's Avatar
tinman52
Welder User
Does this help at all? If not, maybe someone has a parts diagram......
Old Jan 6, 2013 | 09:18 AM
tyrantsparky
Thumbs up
Thanks for the help! That is excellent. Now I need to find that piece that attaches the carb to the accelerator arm
Old Jan 6, 2013 | 03:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1962 F100 223 I-6: Which transmission? Automatic, 3 speed manual, 3 speed w/overdrive, 4 speed manual.
Old Jan 6, 2013 | 04:02 PM
tyrantsparky
The truck is a four speed manual.
Old Jan 6, 2013 | 04:51 PM
NumberDummy
There are two possible 223 I-6 rods.
COTT-9A717-A .. Rod-Carburetor to Bellcrank / Obsolete
1960/62 F100/600 / No Ford Dealer or obsolete parts vendor has any.
B5A-9747-A (replaced C1TT-9A702-C ~ 9.75" long) .. Rod-Bellcrank to Accelerator ~ Cut to fit / Obsolete
1961/62 F100/250 / 1961/64 F350/600 / 1963 F100/250 before serial number 330,001.
WESLEY OBSOLETE PARTS in Liberty KY has 12 = 606-787-5293.
Old Jan 6, 2013 | 05:37 PM
tyrantsparky
I apologize but my ignorance is showing. To make sure I'm clearing what I'm missing, it would be the clip that attaches to the ball end on the throttle part of the carb and then attaches to the hinge like arm on the end of the accelerator rod. Does that end also need an attachment with the ball end?
I truly appreciate all your input and help in getting this worked out.
Old Jan 6, 2013 | 09:48 PM
tinman52's Avatar
tinman52
Welder User
The carb to bellcrank (L shaped arm) link is attached with a snap clip/ball on both ends.
Robert566
Dec 9, 2016 09:17 PM
silar
Sep 18, 2014 08:10 AM
jtindale
May 2, 2012 04:18 PM
low54
Jul 19, 2010 02:04 PM
dave boley
31
Aug 1, 2009 12:55 PM
