Adding 1" carburetor spacer question ?
Old Dec 31, 2012 | 10:09 AM
tasboj's Avatar
tasboj
I been having a problem on my 390 with a 2bbl carb,the gas boils up in the carb wen I turn it off, any ways I have Seen here that the solution for this is to add a spacer between intake and carb,
My question is do I remove the aluminum spacer which water flows thru and replace it with the 1", or do I stack it on top of the existing one,
If that is so,I am having a hard time finding 3" or 3 1/2" studs. and if I have to remove the aluminum spacer,where is the gain, don't I add the spacer to get it higher from the intake to prevent heat from boiling the fuel in the carb, please help I am confused.
Thanks once again.
Jesus N AKA Tasboj
Old Dec 31, 2012 | 10:22 AM
HIO Silver's Avatar
HIO Silver
The OEM spacer (with coolant pass-thru) is there to prevent carburetor icing in cold weather. You can delete it if that is not an issue not likely to occur in your area. Re-route that coolant hose to a T in the heater core return line or change the fitting on the intake manifold to delete the port. Install the 1-inch Trans-Dapt spacer per instructions.
Lastly, consider addressing the high underhood temps by installing heat shield under the carb, insulating the fuel lines, or.... going with an electric fuel pump, a bypass regulator, and a fuel return line so that the carb is always receiving cool(er) fuel.
Old Dec 31, 2012 | 10:48 AM
tasboj's Avatar
tasboj
Thanks HIO for the quick response and suggestions,I just step into the 73-79 forum to kill some time because I know you guy always come thru with fast lightning answers,
By the way it Look like you were having a blast at that honey hole, wish I lived closer Thanks for the help.
HAPPY NEW YEAR 2013
Old Dec 31, 2012 | 01:21 PM
MIKES 68 F100's Avatar
MIKES 68 F100
most of the after market spacers come with new studs,gaskets and bolts .
Old Dec 31, 2012 | 01:30 PM
HIO Silver's Avatar
HIO Silver
HAPPY NEW YEAR 2013
Same to ya.
That honey hole is a gold mine... he's got a few bumpsides in the yard too along with a two Mustangs, early Mavericks, two early Econolines, a zillion early Broncos, and at least five Dentside crewcabs. I dang near whipped out my checkbook for a 67 shortbed and a 69 flareside but alas, I have nowhere to park it.
Old Dec 31, 2012 | 06:36 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Post Heat shield and spacer
The heat shield can go in one of two places. I might suggest you keep the hot-water spacer. You can block or put a valve in the hose to the spacer for summer. If you do this, you can put a simple heat shield UNDER the spacer. Use multiple gaskets, of course. If you use the plastic spacer, it goes under the heatshield.
You might check for interference with other things like the linkage and things. I made a big shield out of 1/16th aluminum, turned up the edges, and cut a slot for the linkage. Keep the separation between the two holes.
It worked great in Las Vegas at 111 degrees. I tested the temps above and below the shield with a remote thermometer. Lost the data, but it sure made a difference. Polished stainless would be better, but it does get grungy fast.
With this technique, you can keep the anti-icing and warm-up benefits of the hot-water spacer. You might need the effect at temps as high as 53 degrees in high relative-humidity conditions, according to an engineering report I read.
Photos in my Carburetor Archive.
https://www.ford-trucks.com/user_gal...219242.520.390
Keep the silicone seal away from the inside of the gasket surface. I put it on the outside only, and it bulges out.
Kevin
Old Dec 31, 2012 | 07:54 PM
willowbilly3's Avatar
willowbilly3
I fought the same issue and tried different spacers. I finally went to a Hollet 2 bbl. and cured the problem
Old Jan 14, 2013 | 08:27 PM
tasboj's Avatar
tasboj
Hey guys sorry for the time off,I am ready to install my carb spacer, but here is my thoughts on how to put it together,
1- leave the carb spacer where coolant runs thru.
2-add the black 1"in spacer on top. (shown in picture below)
of course with gaskets in between each spacer,intake & carb.
3-Install carburetor.
Now I know that some of you guys suggested taking off the coolant spacer or add heat shield, but I have herd that adding height to the carb= more HP which to me that is a plus, besides solving the boiling fuel problem.Now I got the spacers at the JY that is why I don't have the longer studs to install the two spacers and carb.Longest stud I could find was 3"in not long enough, so I made my owen bought 4 bolts 3 3/4" L x 5/16" Dia cut the heads off and used a die to cut threads. fine one side course on the other, here are some pictures of the ordeal, please let me know if it is true about the extra HP.I will post some pics wen its done.
Thanks again.
Old Jan 15, 2013 | 04:55 AM
willowbilly3
Theoretically more power but seat of the pants, doubt if you will notice.
Jpegg01
May 25, 2018 10:11 PM
swolh
27
Feb 8, 2015 10:45 AM
Flying Finn
Nov 24, 2011 10:57 PM
F-250 restorer
Apr 14, 2009 09:40 PM
marilyn
Oct 22, 2005 07:08 AM
