Just got my new UVCH... Now what.
#11 on this thread:
https://www.ford-trucks.com/forums/1...ain-p1316.html
It really isn't that big of a deal.
I'm still trying to figure out my issue. Good luck
Its simple once you have the valve cover off, basically you have 4 injectors and 4 glow plugs. Each injector gets a plastic plug with the metal clip. And each glow plug gets the female plug, I believe it is white. Hook up the injectors first, I think it is easier. Then use a pair of needle nose to hook up the glow plug wire, helps to push it on to the plug. A good head lamp will help you see everything more clear.
Good luck man
Good luck man
onelionhunter
20
02-15-2011 10:11 PM
Brad4321
09-10-2006 04:09 PM
