glow plug question
Old Nov 4, 2014 | 07:59 PM
mybigredford's Avatar
mybigredford
glow plug question
drivers side gp measure .4-.5 ohms and passenger side measures 1.1-1.2 ohms, are the pass side no good?
Old Nov 4, 2014 | 08:30 PM
F350-6's Avatar
F350-6
Pretty odd to have that many go out with a similar reading all at once. I'd suspect the wiring to the glowplugs first.
Maybe it's time to pull the valve cover and ohm the glow plug directly. Of course if you go through the trouble of pulling the valve cover, maybe you should consider having some glow plugs on hand since getting the valve cover off is the hardest part of the whole job.
How do the injectors ohm out between the two banks?
Old Nov 4, 2014 | 08:38 PM
mybigredford
Im not sure i know what you mean by ohm out, i tested the gp's by dissconecting the plug going into the valve cover and the twp outside pins, and like i said the drivers side all ohmed out at .4-.5 and passenger side 1.1-1.2 . so does that mean the pass side is no good or are they all in allowable specs?
Old Nov 5, 2014 | 08:12 AM
DND58's Avatar
DND58
You're going through the same motions, just metering on another set of pins on the valve cover connector for the injectors. See the attached link. If the passenger side is also different for your injectors, it could be a UVCH wiring problem more than plugs.
https://www.ford-trucks.com/forums/8...ly-please.html
Old Nov 5, 2014 | 07:03 PM
F350-6's Avatar
F350-6
You took an ohm reading of the glow plugs through a wiring harness. If you remove the valve cover, you can ohm the glow plug itself by testing the tip of the glow plug against a ground to check the reading. You can also check each end of the wiring of the UVCH harness (at the connector for the valve cover and the connector to the glow plug to make sure the wiring is good.
You can even remove the glow plug from the motor and ohm the tip against the threads, but if you go that far, why not replace them?
Jerseypiasan
Nov 12, 2017 06:04 AM
Mass Man
Mar 11, 2013 09:12 PM
bly8397
Dec 28, 2012 07:50 PM
onelionhunter
20
Feb 15, 2011 10:11 PM
potsiewebber
Jan 12, 2008 06:19 PM
