locking hubs
Old Dec 25, 2012 | 11:36 PM
FoundOnRoadDominatin's Avatar
Question locking hubs
Am thinking about switching out the auto locking hubs on my 81 f150 for some WARN manual hubs but was just wondering if there were any special considerations that I should take before jumping into this little project.
Old Dec 26, 2012 | 07:37 AM
bashby's Avatar
bashby
I got some milemarker hubs from Amazon for my brothers truck. They seemed pretty well made and reasonably priced.
Old Dec 26, 2012 | 07:44 AM
Franklin2's Avatar
Franklin2
They usually sell a "kit" that you need with the conversion. The auto hubs must use a different way to hold the wheel bearings in, because the kit usually gives you new locking nuts for the wheel bearings. I have never done the swap before, but remember seeing the kits online at autozone and other places.
Old Dec 26, 2012 | 04:37 PM
JayzDaddy's Avatar
JayzDaddy
Do auto hubs have unit bearings or is that full time?
Old Dec 26, 2012 | 05:45 PM
bashby's Avatar
bashby
These trucks all have 2 tapered roller bearings, old school stuff. I'm not sure what year they went to unitized hub assemblies.
Old Dec 26, 2012 | 06:08 PM
Gary Lewis's Avatar
Gary Lewis
Yes, I've seen those kits for changing over from auto-locking hubs to manuals, and they do say they are required. I just changed from the standard Warn hub that came on the truck to MileMarkers for two reasons. One, the MM's have no plastic in them while the Warns have a lot of plastic. Two, I liked the looks of the MM's better.
But, I had fits getting three of the six screws out of one hub, and discovered that the heads of the screws are only about .005" smaller than the recess into which they go. As it turned out, those three were seized in that recess. So, if you do go with MM hubs I'd recommend using some kind of lube on the heads of the screws so you can get them out later.
Edit: Forgot. The torque for the first nut is 50 ft-lbs, and you torque it while rotating the wheel to seat the bearings. Then you back the nut off ~45˚ and try to put the retainer washer on. But, you'll probably have to rotate the nut a bit to get it to the nearest hole for the pin to go through. Then the lock nut is put on over that and torqued to 50 ft-lbs.
Old Jan 4, 2013 | 01:56 PM
kraylake's Avatar
kraylake
Dunno if an autohub to manual hub change out is the same as a manual hub upgrade but here is a link to a manual hub upgrade i did on my 1980 f350 awhile back. Its a quick and easy change.
https://www.ford-trucks.com/forums/1...l#post11236959
Old Jan 4, 2013 | 02:50 PM
I have actually read your post several times and even printed out all the pictures to help me on the project. I still haven't addressed the hubs yet. I decided to throw more money for new replacement parts around the engine.
but your post did give me a clearer picture of what to expect.
Old Jan 4, 2013 | 03:57 PM
bashby's Avatar
bashby
Then rep the man, already!
Old Jan 4, 2013 | 05:48 PM
dustybumpers's Avatar
dustybumpers
Jeff's bronco graveyard sells a mile marker kit to convert the auto hubs. It comes with some really great instructions. I did my 94, and it is a great improvement
Here's the link to Jeff's
Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
The hardest part of the conversion is getting the auto lock wheel bearing nut out. They were one time use, and not available anymore.
One of mine came out, no problem, I had to destroy the other.
The new set up uses the wheel bearing tool that's available in any parts store.
Old Jan 4, 2013 | 09:02 PM
bashby's Avatar
bashby
On a 94? Never seen that before.
Old Jan 5, 2013 | 06:14 AM
dustybumpers
It's still a dana ifs 44. All shift on the fly trucks were set up with auto hubs
Old Jan 5, 2013 | 06:28 AM
bashby's Avatar
bashby
I took that to mean you had to remove the factory wheel bearing nut and it was some kind of one time use thing.
posbeater86
Nov 19, 2007 03:43 PM
gopher2
Sep 1, 2007 06:24 AM
Mudder
Bronco II
Nov 16, 2004 05:30 PM
tygarcia
1978 - 1996 Big Bronco
Apr 25, 2004 07:07 PM
