auto to manual hubs / wheel bearings
i got a 1996 f150 4x4 XLT i wanna swap my auto hubs to manuals. will i have to buy new hub spindles and backing plates? I see some hub on ebay like this http://cgi.ebay.com/Warn-4WD-Premium...QQcmdZViewItem
can i just pop those in ?
Manual hubs are a direct swap from the auto hubs, you don't need to replace your spindles and I'm not sure what you mean by backing plates, but you have to buy a conversion kit. If you're going to go with Warn hubs you might as well just buy the warn conversion kit (although I'm not sure it matters), you can find the part number on their website. I did this swap several months back, went very smoothly. Post back here if you have any questions.
Well if you're current seals are good you can reuse them so long as you don't damage them when you take them out. I reused mine when I did my wheel bearings. I'm assuming your replacing both inners and outers; if you replace just the outers you won't need to remove the seal nor the rotors. If you ARE replacing inners then you'll have to remove the rotors and the seals, just be careful and you should be able to reuse them if they're in good shape.
go some where else I work on theses trucks all time and just sold a 96 .I repacked the bearings before sold and seal was like $14,00.(But they may have changed for the late 96 ) I can get new bearings races and seals for about $50 any where . If have 3 bolt in hub you will need the conversion kit with them . Good luck on the swap .
FordMan57
01-04-2020 10:51 PM
forddriver17
01-18-2009 05:29 PM
