E40D Issues
Old Dec 27, 2012 | 05:04 AM
  #31
427 fordman's Avatar
427 fordman
Originally Posted by pj1961
I guess I should have known better than buying a POS Ford anyway. Oh well
Phillip
POS ford? You can go away now....
Old Dec 27, 2012 | 07:49 AM
  #32
fordpride's Avatar
fordpride
Your next step would be to have a pressure test done.
Old Dec 27, 2012 | 07:56 AM
  #33
pj1961's Avatar
pj1961
I didn't mean all Fords. I usually buy my trucks new, and have had good luck with the Ford Diesel trucks. But this truck, which I bought with 213,000 miles on it is a POS. But hey it is a 1997, so what should I expect. I just don't have the money now to rebuild it. So before it quits, I will try and trade it off. And make payments on a new one.
Phillip
  #34
pj1961's Avatar
pj1961
Pressure test on what
Old Dec 27, 2012 | 07:58 AM
  #35
pj1961's Avatar
pj1961
I talked to a shop yesterday. Quoted me 1895 for a rebuild on the transfer and converter. Not worth it on a 97
Old Dec 27, 2012 | 08:05 AM
  #36
fordpride's Avatar
fordpride
on the trans.
Old Dec 27, 2012 | 08:06 AM
  #37
fordpride's Avatar
fordpride
You do realize the motor in your truck is worth $1500-2000 bucks.
Old Dec 27, 2012 | 08:21 AM
  #38
pj1961's Avatar
pj1961
I figured something like that. Its an extended cab 2 wd, with the XLT package.The body seems pretty strait, except for the rear of the bed on the passenger side. Has some damage from a blowout. The interior is ok, as it was a farm truck before I got it. I wonder what a 97 Ext Cab with a bad trans would be worth on a trade in.
Phillip
Old Dec 27, 2012 | 08:24 AM
  #39
pj1961's Avatar
pj1961
Oh and the transmission fluid was brown , on the rag when I checked it. What does that mean?
Old Dec 27, 2012 | 09:39 AM
  #40
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Brown trans fluid means the fluid is worn out and needs to be changed.
Old Dec 27, 2012 | 10:36 AM
  #41
pj1961's Avatar
pj1961
Without knowing whether the fluid was changed regularly, is it safe to change it? Rumor has it, if you change one that hadnt been serviced properly, you will kill it.
Phillip
Old Dec 27, 2012 | 11:00 AM
  #42
oldbird1965's Avatar
oldbird1965
Refer to post #27, Mark is the expert.
Old Dec 27, 2012 | 01:26 PM
  #43
fordman67's Avatar
fordman67
I don't see how it is not....200000 miles...yep that's half at worst way to being worn out...my 96 with 321000 runs and drives great.I plan a new engine at 400000 IF I have it ready...if its not done..then we will see how far it goes before it gets swapped...my truck will live FOREVER! Or some non driver takes it from me.
Old Dec 27, 2012 | 02:40 PM
  #44
Mark Kovalsky
Phillip
An old urban legend that just won't die because people that don't know anything about the subject keep quoting it.
Yes, Mark is the expert.
Originally Posted by fordman67
I don't see how it is not....200000 miles...yep that's half at worst way to being worn out...my 96 with 321000 runs and drives great.I plan a new engine at 4000000 IF I have it ready...if its not done..then we will see how far it goes before it gets swapped...my truck will live FOREVER! Or some non driver takes it from me.
I'm willing to bet the original engine is going to die long before 4000000 (4 million) miles.
Old Dec 27, 2012 | 02:43 PM
  #45
pj1961's Avatar
pj1961
Doesn't matter anyway, as I don't have 1895. So it appears, the truck has to go.
Phillip
