E40D Issues
Old Dec 26, 2012 | 12:04 AM
oldbird1965's Avatar
oldbird1965
Believe it or not these trucks are still in demand. I know your pissed, I would be too. Clear your head then try the simple things talked about here. When these babies run right and they do most of the time, they are an awesome truck. Don't 'give' it away!!
Old Dec 26, 2012 | 02:10 AM
Mr.Dilac7.3's Avatar
Mr.Dilac7.3
I dont know what you use your trucks for. But after paying 3,000 for a truck with an engine that taken care of properly will get you close if not over 500K before anything close to a rebuild is not bad. Now throwing 2500-3000 on a trans buld is not that bad. Any decent shop will be able to upgrade to Kevlar Cluthces, steel planetary gears, a larger valve body and shift kit for that price. I had the same thing done to mine and the darn thing tows like its brand new.
Old Dec 26, 2012 | 07:05 AM
fordman67's Avatar
fordman67
By the way pos only has 321000 and drives great.if you look around pricing is better than you think.I can get one here done for half the prices discussed and have a great truck again.you owned an 05? Yea...that was a bad idea. This 97...NOT a bad idea!
Old Dec 26, 2012 | 07:49 AM
pj1961's Avatar
pj1961
97 F250
I am in the construction business, so I seldom tow anything.The man whom I boghth this truck said it had a shift kit in it. Whatever that is. I would like to adjust the linkage, or possibly repair the shifter. So at least the gears will align. And I will add transmission fluidAs far as the repairs though, can someone assist me with making the small repairs mentioned? I'm a carpenter, not a mechanic.
Phillip
Pj61@art.jet
Old Dec 26, 2012 | 07:50 AM
pj1961's Avatar
pj1961
That's pj61@att.net
Old Dec 26, 2012 | 08:07 AM
fordpride's Avatar
fordpride
There is two screw under the dash in the shift linkage that is know for coming loose. And will cause it to be hard to get it in the rite gear.
I have a pic of them but it will be around 5pm before I can post it.
Old Dec 26, 2012 | 08:10 AM
fordpride's Avatar
fordpride
Click on the blue link it has a pic
TheDieselStop.Com Photo Hosting - Solving floppy automatic shift lever problem
Old Dec 26, 2012 | 08:39 AM
Hussler's Avatar
Hussler
Originally Posted by fordpride
That is what I was thinking but didn't have pics to show. Tried to rep ya but no dice this time around ...
Old Dec 26, 2012 | 09:45 PM
pj1961's Avatar
pj1961
Well I checked the transfer fluid and the screws, and both were fine. Put the truck into reverse and it wouldn't engage intuitive increased the rpm speed. Then it went into gear. Also when driving in town, the truck seems like it drops out of drive when I let off the accelerator. Some type of kickdown into a lower gear. And the rpm speed remains at like 1500 rpm until I accelerate again. I wonder if a fluid and filter change might help it. The fluid looks kinda brown on the rag.
Phillip
Old Dec 26, 2012 | 09:55 PM
oldbird1965
A change might be in order. I have heard though that sometimes changing the fluid and filter will shake a lot of grud loose and cause a complete trans failure. Just though I would throw that out there but if it was mine, I would change it.
Old Dec 26, 2012 | 09:56 PM
Action4478's Avatar
Action4478
Phillip
Thats what you get for buying a Ford .....Sell it & buy a chevy .....
Old Dec 26, 2012 | 10:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've also heard a lot of things that are not true. This is not true, either.
Old Dec 26, 2012 | 10:09 PM
  #28
fordman67's Avatar
fordman67
Hopefully the filter is clogged.sounds more and more pump having a hard time at low speed.
Old Dec 26, 2012 | 10:16 PM
  #29
oldbird1965
That's what I get for opening my big mouth, please disregard all my posts in this thread. Over and Out!
Old Dec 26, 2012 | 10:45 PM
  #30
fordman67's Avatar
fordman67
There ya go...that's a great idea... ????
