Help locating clutch push rod upper bracket
Old Dec 22, 2012 | 07:21 PM
cyrrius's Avatar
cyrrius
I've been searching the different parts sites for the past three hours looking for the bracket on the right side of the brake pedal that the clutch push rod hooks into. The hole in it is severely elongated and causes problems with the pedal sticking. The bracket I'm looking for is shown in this image:
<a href="http://www.flickr.com/photos/cyrrius/8298960616/" title="Pedal Assembly by cyrrius, on Flickr"><img src="http://farm9.staticflickr.com/8359/8298960616_cf07018a46.jpg" width="375" height="500" alt="Pedal Assembly"></a>
Old Dec 22, 2012 | 07:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Sent you a PM
Old Dec 22, 2012 | 08:00 PM
mark a.'s Avatar
mark a.
You could weld the hole shut and redrill it or cut it off, trace it out on a new piece of metal, drill a new hole & weld it on.
Old Dec 22, 2012 | 09:11 PM
cyrrius's Avatar
cyrrius
Thanks Mike! Got the message! Mark, I have definitely thought about that, but I'm concerned about the unknowns such as, what happens if I get the hole off-center. I'm learning as I go with this truck and I'm only a year into it.
Old Dec 22, 2012 | 11:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Clutch release lever ('push rod') has nylon bushings on both 90 degree ends. The bushings crack apart/disintigrate, the 90 degree ends begin to crack, eventually snap off. Not pleasant!
XXXX-7A554-X .. Clutch Pedal Lever-4" long x 1 1/8" wide / Obsolete
1978 F100/350 & Bronco from serial number BA0,001 / 1979 F100/350 & Bronco.
ONE available NOS / I assume Mike sent you the part number/source/phone number in that P/M since we both use the same two parts locator sites (one of which only 3 FTE members have access to and that's what it's listed on).
The thing is: When there's only one available, if we post the part number/source, someone else might snag it.
Old Dec 23, 2012 | 01:12 AM
mikeo0o0o0's Avatar
mikeo0o0o0
ONE available NOS / I assume Mike sent you the part number. When there's only one available, if we post the part number/source, someone else might snag it.
Old Dec 23, 2012 | 06:46 PM
cyrrius's Avatar
cyrrius
Thanks ND. Mike sent me the info for it. I appreciate the help guys.
Old Dec 23, 2012 | 11:21 PM
psquare7575's Avatar
psquare7575
I actually found one for $15 shipped NOS last month.. I googled the part # and a list came up, that was actually several years old. Parts place still had it.
Old Dec 24, 2012 | 09:33 PM
cyrrius's Avatar
cyrrius
Psquare, I found the listing on NOS and they were out of stock. I googled the part number too. I spent several hours searching with no luck. I'm pretty sure my problem is solved though. Just waiting on a call back.
Old Dec 24, 2012 | 09:37 PM
psquare7575
Space Coast Shelby? I was the buyer. Sorry.
Bluethunder3320
Nov 17, 2014 07:04 PM
slipkorn34
Mar 1, 2011 05:34 PM
Roy C
Oct 1, 2010 02:38 PM
samahi72
Mar 28, 2005 10:47 PM
