Weak leg Stiff Clutch Help?
Old Feb 9, 2005 | 05:00 PM
samahi72's Avatar
samahi72
1960 4 speed, 232 6 cyl. After 5 knee surgeries and just waiting for the right moment to get a knee replacement, my left leg is really weak. Pushing in the clutch is really a chore and it aggravates the knee. Also it seems the clutch is unusually stiff. Any suggestions to make it easier???
Old Feb 9, 2005 | 05:07 PM
Madathlon's Avatar
Madathlon
I also Have a 1960 F-100 with the 4sp and a 223.. The cluch is stiff with al new parts.. its the way its made as far as I can tell.. All I can say is to rigg a power boosted clutch. Or have a Auto trans for it installed...
Old Feb 10, 2005 | 12:16 PM
Earl's Avatar
Earl
I have a bit of a problem with my left knee as well. If your 1960 linkage is like my 1956 linkage in the photo below, you might try this modification.
I'm thinking about modifying the "U"-shaped metal connection bar between the frame-mounted pedals and the transmission (arrow in photo). The arrow in the photo shows the original hole where the clutch linkage rod goes through. If I drill a second hole above the original hole, and then move the linkage rod to the new hole, the amount of effort required to depress the clutch will be less. The higher the new hole is, the lower the effort.
HOWEVER, you don't get something for nothing! The clutch throw distance will be reduced as you move the new hole farther up on the "U" connecting bar. I suspect I can move the hole up about 1/2" and adjust the linkage so the throwout bearing is not engaged with the pedal released and still get the clutch to disengage with the pedal depressed. If I drill the new hole toward the front of the "U", I can try it out and still have a second shot at another hole toward the rear of the "U" if I need a different vertical location.
At any rate, it's a simple enough thing to try, and I can always put the linkage rod back in the original hole if it doesn't work. In the worst case, I could make a whole new "U" connecting bar without too much effort.
Old Feb 10, 2005 | 12:34 PM
bigwin56f100's Avatar
bigwin56f100
Forgive me if I'm wrong but isnt a 1960 a hydraulic clutch set up? I'm not real familiar with your style set up but if there is a return spring down at the clutch fork maybe install a weaker spring?
Nice pic George but I dont think it will work for his application.
Kevin Bigwin
Old Feb 10, 2005 | 12:37 PM
kooper909's Avatar
kooper909
Bigwin56f100 is correct, '57-'60 used a hydraulic clutch.
Old Feb 10, 2005 | 12:54 PM
Earl's Avatar
Earl
Sorry Samahi, didn't realize the difference in clutches. You're welcome to visit and rest your knee by using my clutch - it I ever get the rest of the truck done.
Old Feb 10, 2005 | 02:03 PM
Col Flashman's Avatar
Col Flashman
You have only two options that I've come up after disscussing a similar problem w/ Father about the '58 F-350 that I traded for the '58 M-100.
Lighter Return Spring or go w/ a Cruise-O-Matic.
Cheers
Colonel Flashman
Old Mar 28, 2005 | 07:51 PM
Roy in TX's Avatar
Roy in TX
Thumbs up Stiff clutch
My 57, 223, 4 spd is very stiff also. Been told there are aftermarket clutch and pressure plates available that will cure the problem. They have more "fingers" on the pressure plate than do the orginal therefore they can apply more pressure. Dont know how much these buggers are , but I am going to have to do something. My wife wont even drive it. What !! you say am I griping about. Yea I want my wife to drive it, she might let me spend more on it. !!! Roy
Old Mar 28, 2005 | 08:00 PM
4tl8ford's Avatar
4tl8ford
The C***y clutch/Pressure plate are much easier to work it's the design of the fingers. You would probubly have to redrill your flywheel.
Amoung all my other ailments is a bum left leg and I don't like automatics.
Old Mar 28, 2005 | 10:47 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
If the clutch is hydraulic why cant a booster be installed like brakes have?
dieselsubmariner
20
Oct 15, 2013 09:14 PM
jFa350
May 31, 2013 06:03 PM
jaydez
17
Sep 21, 2004 09:59 AM
Supercab
21
Jan 18, 2004 04:47 AM
desperado_18_2000
Nov 18, 2003 09:45 PM
