Hello everyone. I am helping a friend with a 2004 F350 auto 4X4.
I pulled the codes 0401, 2614 and 2617.
I read that the 2614 and 2617 codes wil show up during a no start situation so I am asking if the CPS is the likely problem as it is on the 7.3?
This all started with water in fuel light and I have replaced both filters. The truck started after I replaced them and seemed to run ok but the next morning it would not start. I plugged the block heater in just in case the glow plugs were having problems.
The engine cranks fast and attempts to fire but never starts.
I'm not quick with the dtc numbers. I can't remember which one is bad if the tach moves. Either cam or crank sensor. Maybe someone will chime in here. Was any of the codes related to cam or crank?? Cps is cam, I think cks is crank.
Do you remember if all the codes came at the same time. I remember last time I lost the crank sensor,, I got a crank sensor code first, then the cam sensor code followed after one long no start.
