No start
Old Dec 1, 2012 | 11:49 PM
  #31
95_Dually's Avatar
95_Dually
That would be awesome Tim
Old Dec 1, 2012 | 11:50 PM
  #32
m-chan68's Avatar
m-chan68
Furthermore, is there any fuel in the secondary fuel filter housing when you remove the cap? Cycle the ignition key from OFF to RUN once and then remove the cap. If the housing is empty of fuel, it definitely sounds like your HFCM needs replaced. During every key-on cycle, fuel is supposed to fill up the secondary fuel filter housing RAPIDLY and NOT bleed back down. It should remain in the housing even after the fuel pump stops running.
Old Dec 1, 2012 | 11:52 PM
  #33
Fal-308-Win's Avatar
Fal-308-Win
How bout tomorrow after the rain?
Old Dec 1, 2012 | 11:53 PM
  #34
BLADE35's Avatar
BLADE35
really need a Gauge that reads Live Data to get anywhere with this truck
I use ScanGaugeII buy it from Autozone has everything you Need Just have to program the Gauges when you get it I have fixed my truck several times with it it paid for itself many times over now
Others use DashBoss but takes smartphone and Wireless OBDII Adapter it takes more to set up but Also Does what you need it to the display is Nicer
The best thing is AE With Ford Enhanced data best thing for a DIYer its 360.00 from Riff Raff Diesel goes to your computer it will give the ability to control the truck for specific testing
Old Dec 1, 2012 | 11:58 PM
  #35
BLADE35's Avatar
BLADE35
Just saw your Post Tim that would be Awesome if you did that Reps to you if it will let me
I kinda thinking like Mike the truck sounds like almost starts so maybe FICM maybe a HPO Leak
I have saw 1 or 2 trucks here that had enough HPO Pressure For the PCM to command the FICM to Fire the injectors but not enough HPO Pressure to Start it if that makes sense
Old Dec 2, 2012 | 12:01 AM
  #36
Fal-308-Win
Me thinks we dropped Benny out of the loop
Old Dec 2, 2012 | 12:05 AM
  #37
Fal-308-Win
Sam is tomorrow OK? I know it's church and all but I. Work 40 + a week and have to work next Sat. So time is pretty tight for me.
  #38
BLADE35's Avatar
BLADE35
Take Note of EVERYTHING Mike and Cheezit and Bismic Mentions Here and make SHURE to check those things Out
Here what I would Check
ICP
ICPV
IPR%
RPM
Volts
FICM MP
FICM LP
FICM VP
FICM Sync
CMP/CKP SYNC
V-REF
FPW ( Fuel Pulse Width)
Check at KOEO and also at CRANK
Old Dec 2, 2012 | 12:07 AM
  #39
BLADE35's Avatar
BLADE35
Nope Im Gona sit right here and wait for them Numbers LOL
Oh and Fuel Press if possible
My List was all for SGII or OBDII Port
Old Dec 2, 2012 | 12:09 AM
  #40
95_Dually's Avatar
95_Dually
I am trying to locate the ICP. The secondary bowl has fuel
Old Dec 2, 2012 | 12:10 AM
  #41
95_Dually's Avatar
95_Dually
It fills the bowl very quickly with fuel as well.
Old Dec 2, 2012 | 12:11 AM
  #42
Fal-308-Win
No fuel pressure gauge here but I can get the rest.
Old Dec 2, 2012 | 12:12 AM
  #43
95_Dually's Avatar
95_Dually
Tim, tomorrow sounds good. Pm me so I can give you my info.
Old Dec 2, 2012 | 12:13 AM
  #44
BLADE35's Avatar
BLADE35
Early 04
Late 04 this is the only sensor in the Passengerside Valve cover
and depending what one you have will tell use what type HPO System you have
Old Dec 2, 2012 | 12:16 AM
  #45
BLADE35's Avatar
BLADE35
here is a Better pick of early ICP Location from my truck
You can use a long Pick to unhook the clip and pull harness off
