No start
Dec 2, 2012 | 12:30 AM
I tried to start the truck.....it attempts to fire but never runs. I am not sure of the ICP location. If it is behind the turbo, I need to remove something to get my arm down there. It is late, cold and raining all over me. For tonight it is Truck 1-Sam 0.....
Dec 2, 2012 | 12:31 AM
Benny, that 2nd pick looks like a sensor on this truck. Thank you.
Dec 2, 2012 | 12:32 AM
I tried to rep you again but alas, I cannot.
Dec 2, 2012 | 12:43 AM
Quote:
Originally Posted by
95_Dually
So its in the passenger side valve cover
Great unplug it and try to start PCM will use a Default value
Note the condition of ICP Plug if there any oil on it the sensor needs replaced
I dont think you will get off this easy as bad ICP but never know
Dec 2, 2012 | 12:46 AM
I meant the 2nd post with the pic of yours. Sorry about the miscommunication.
Dec 2, 2012 | 12:49 AM
That's because the 2nd pic that Benny posted IS that of an ICP sensor on a 7.3L engine.
M - Chan, Benny, I got the address, we'll scan it around 9:00 am ish' pacific standard time and post the numbers then. Good Night All, Tim
Dec 2, 2012 | 01:00 PM
BLADE35
Take Note of EVERYTHING Mike and Cheezit and Bismic Mentions Here and make SHURE to check those things Out
Here what I would Check
ICP
ICPV
IPR%
RPM
Volts
FICM MP
FICM LP
FICM VP
FICM Sync
CMP/CKP SYNC
V-REF
FPW ( Fuel Pulse Width)
Check at KOEO and also at CRANK
Tim helped me this morning and here is the data we received. The first value will be KOEO and the second value will be Cranking.
ICP 26 1555
ICPV .20 1.80
IPR% 14.4 42.1
RPM 0 146
Volts 12.5 10.5
FICM MP 48 33 down to 15 while cranking
FICM LP 12.5 10.5
FICM VP 12.5 10.5
FICM SYNC 0 1
V-REF/CVI 4 4
FPW 0 2040
I hope this info is helpful. Tim believes the problem is the FICM due to the low voltage reading while cranking.
Dec 2, 2012 | 01:24 PM
X-2 on the FICM
Way to go TIM
Dec 2, 2012 | 01:32 PM
m-chan68
That wasnt the valve cover was it ya that pic was my Bad
Dec 2, 2012 | 01:54 PM
Benny, I checked my albums and I have that same pic from years ago. LOL
Dec 2, 2012 | 01:55 PM
Tim mentioned someone by the name of Ed to repair the FICM. Anybody know how I can contact Ed?
Reason: Spelling.
Dec 2, 2012 | 01:56 PM
95_Dually
So I showed you Your Own Pic LOL
came from Google
I have a few that come up there to
Dec 2, 2012 | 01:58 PM
Dec 2, 2012 | 02:24 PM
Thank you Mark. I wasn't aware that PHP did more than chips....I learned a lot today and it is only noon....LOL
