No oil usage after 9,500 miles?
Old Nov 23, 2012 | 01:56 PM
smokersteve's Avatar
smokersteve
I have an oil bypass filter and use synthetic. I got 10,000 miles and test the oil.
Ever since I changed the oil 9,500 miles ago I have not had to add any oil. I have only had one result come back with 6.5% fuel. But that was it. In about 500 miles I will test like normal and see if I have any fuel dilution but I should not have any...
Do your trucks eat oil???
Old Nov 23, 2012 | 02:39 PM
BLADE35's Avatar
BLADE35
NO I dont eat oil yet
I know some auto will wear valve guides and create a Vac right there and burn alittle oil but this dont happen till 200,000mile or more on my gassers I changed oil every 3-4K but never had to add Oil
Who does your Oil Testing????
Something sounds Fishey with the High Fuel Delution that corrected itself or did you rering injectors or something????
Be careful Steve I think Extended Oil Changes are what Really HARD on the Lifter Bearings more than anything
Eat a Lifter and Its not worth the Oil Saved IMO
Old Nov 23, 2012 | 04:51 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
That's a long time on the oil for a 6.0.
I'm curious too who is testing the oil. I recommend Oil Analysts Inc. Not a big fan of Blackstone.
Josh
Old Nov 23, 2012 | 05:27 PM
Yahiko's Avatar
Yahiko
OK So What I would like to see is the oil viscosity test done by
a first rate lab and not by inferred results. To tell us just how
much of the oil has been sheared. Her is a bit of info on this.
Oil Viscosity - How It's Measured and Reported
Sean
Old Nov 23, 2012 | 05:49 PM
dannyboy950's Avatar
dannyboy950
Nice article so that means we are no longer supposed to do the old finger seperation test. LOL
What can I say I am a very old mechanic LMAO
Old Nov 23, 2012 | 07:20 PM
smokersteve
I test mine at Blackstone.
I have never had any fuel turn up except that one time.
I had no injector work.
Josh
I have good results going 10,000 miles and have posted my results previously with good reviews.
Should I change who tests my oil?
Old Nov 23, 2012 | 07:24 PM
BLADE35's Avatar
BLADE35
Whats that????????
I know they do High tech testing but I would Like to know
I like the old school way to test injectors and such
Old Nov 23, 2012 | 07:29 PM
BLADE35's Avatar
BLADE35
Heard a Few Complaints about Blackstone
I think Bismic knows the details about how the diffrent Places are testing the samples
Old Nov 23, 2012 | 07:37 PM
smokersteve
I would love to hear about that.
Old Nov 23, 2012 | 08:00 PM
BLADE35's Avatar
BLADE35
Maybe send Him a PM if he dont hit/see this thread
I Thinking Blackstone does a Flash Burn test to figure Fuel delution and from what I gather its not the most accurite test for fuel delution
Old Nov 23, 2012 | 09:24 PM
bismic's Avatar
bismic
Blackstone determines the fuel dilution from the flash point test. Not the most accurate way (but they insist it is fine). Many people have had "flyers" with Blackstone and fuel dilution like you describe. The most accurate way for a standard lab to get the fuel dilution is gas chromatography (three methods typically used: viscosity, flash point and gas chromatography).
The metals are done by ICP, so they are fine (as long as their technicians follow proper lab procedures).
Old Nov 23, 2012 | 09:57 PM
smokersteve
What other analysis companies are recommended?
Old Nov 23, 2012 | 10:00 PM
Bullitt390's Avatar
Bullitt390
I like Oil Analysts Inc.
CAT and Deere are high quality as well.
Some NAPA stores have UOA, not sure who they run their reports thru though.
Josh
Old Nov 23, 2012 | 10:06 PM
bismic's Avatar
bismic
Other Options:
<TABLE style="WIDTH: 342pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=456 x:str><COLGROUP><COL style="WIDTH: 342pt; mso-width-source: userset; mso-width-alt: 16213" width=456><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 342pt; HEIGHT: 13.2pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 height=18 width=456>OIL ANALYSIS </TD></TR><TR style="HEIGHT: 12.9pt; mso-height-source: userset" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=17 x:str="http://www.blackstone-labs.com/ ">http://www.blackstone-labs.com/ </TD></TR><TR style="HEIGHT: 30.15pt; mso-height-source: userset" height=40><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 30.15pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=40 x:str="http://www.dysonanalysis.com/ ">http://www.dysonanalysis.com/ </TD></TR><TR style="HEIGHT: 15.6pt" height=21><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 15.6pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=21>http://www.butler-machinery.com/services/product_support_oil.asp
</TD></TR><TR style="HEIGHT: 15.6pt" height=21><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 342pt; HEIGHT: 15.6pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=21 width=456>http://www.polarislabs1.com/</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 342pt; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18 width=456>http://www.oaitesting.com/</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=18>http://www.avlab.com/</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=18>https://www.herguth.com/testing/prodprot.htm</TD></TR><TR style="HEIGHT: 16.5pt; mso-height-source: userset" height=22><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 342pt; HEIGHT: 16.5pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl27 height=22 width=456>http://www.mrtlaboratories.com/</TD></TR></TBODY></TABLE>
I have used:
polaris
mrt labs
butler
They all seem fine. I know that Polaris uses GC for their fuel dilution. I believe that MRTLabs does also - just can't recall for sure.
http://www.polarislabs.com/test-expl...l-dilution.php
Old Nov 24, 2012 | 12:11 AM
dannyboy950
Whats that????????
Lol this was a test showed me by my granpa to tell whether your oil was used up.
Dip your thumb and forefinger in a sample of your oil. Touch your fingers together and then very slowly seperate. For the first couple of centimeters the oil should bridge across from finger to finger. If it don't your oil is too thin.
I always considered it more of a elasticity test myself but ya didn't argue with gramps but once.
Thomh
2009 - 2014 F150
Aug 17, 2017 02:43 PM
fridgeddiesel
18
Feb 9, 2016 12:34 AM
tenntractor
Apr 27, 2008 08:47 PM
NWO_diesel_nut
Apr 2, 2008 07:33 AM
mstepchinski
16
Jul 12, 2004 02:25 PM
