too much fun....
Come up with another FACT that shows the 6.7 pump is no good, please.... and leave accumptions out of it, just the facts you know. Lets try again.....
2-When the pump does go it will take out the injectors = bad engineering.
I don't care if the other manufactures use the system or not, it doesn't make it right.
I have read about other manufactures having problems and have since started to warranty the pump at 100%. From what I understand Ford has not taken this approach.
Again, I expect better and apparently you don't. Your decision.
And your wrong about other manufacturers covering pumps at 100%... GM and RAM (Fiat) will void your warrenty if there's evidence water damaged the HPFP plain and simple!
You are correct if the HPFP experiences a catastrophic failure and it will indeed ruin the injectors.
You have read from Rick that everybody else is getting warranty work and HIS is the only one "assumed" that FORD has denied just because he is Rick. Not because of bad fuel or water, but just because.
If your pump shows water damage, should your warranty cover if JefffH? Remember before you answer that the HPFP is designed to pump diesel and not water.....
I expect that my truck will be and continue to be a great truck with a great motor, if I get a bad does of diesel with water or mixed with gasoline or something that is not USLD then that's my problem. Not fords.
Diesel fuel in the US HFRR score is below Bosch spec
Additives can bring the HFRR up as well as cetane and water demulsifier
The truck has a water filter in the fuel supply that is easy to drain
Drivers have zero control over gas stations diesel supply
So, just like the effort it takes to minimize damage to other areas of the engine, like changing the air filter, oil changes, tire air pressure, I add a demulsifiing lubricity additive to a tank of fuel I buy from stations who are busy and drain the DFCM often. I therefor minimize risk associated with the fuel system, just like oil changes etc.
The data is out there on number of trucks sold and failure of pumps per X trucks sold. It is pretty low. Fascinating is the claims of poor design, comparisons to other manufacurer vehicle warranty claims and doggedly defending one poor guys mission to negatively impact sales of Ford F series trucks, as well as a few who consistantly make claims of new truck pump failures without data to back it up. What is point? What is going to happen to all of us 6.7 owners by claiming a component fails? Nothing is my guess. My take from this ongoing saga is, my claim your new trucks lug nuts are going to losen up and your wheel will fall off should have you starting a new thread with wild ideas about your lug nuts. Us owners concerned about a problem seek out good ideas from other forum folks...see suggestions above for minimizing fuel issues and let us know how it works.
I remember getting a tank of bad gas in my F150 and after burning through that tank of bad gas it went on trouble free for another 100,000 miles without worry. My point is I always felt my F150's were bullet proof. I want to feel that way about my "Super Duty" but I feel the HPFP could be a week link as the miles start to increase. Thats not to mention a possible bad tank of gas or two along the way.
Back in those days, everyone here doted on his every post. You all loved what he had to say....The koolaid was being passed around and everyone was slapping each other on the back having a great time...
The point is, you all respected his opinion then...Well that cuts both ways.
His opinion has changed over time (as most everyones will on different things) and now some of you no longer want to hear from him.
I see it as taking the good with the bad. If you loved all the good things he had to say, then you at least should tolerate what he has to say when you don't like it.
If that is too hard, then you can always just block him.
Rick, I think you should hold out for what you want. These things cost to much to settle for less. When I decided I wanted my Silverado, I had to wait for it as production hadn't started yet. I had a good offer on my old one and took it,,,,even though it meant that I had to drive around in a borrowed mini truck for awhile.
Im personally sick of this crap.time to move on.
LEAVE THE PAST IN THE PAST
There's absolutely no reason to go down this road again. We've been there, done that, and hashed this out a thousand times. Rick started this thread about EGR issues and his CEL coming on again, and turning it into a bash-fest doesn't help anyone.
Posts about how to improve the truck, or mod video from enthusiasts like epic and others, or reports from drivers who have 100K miles already without a pump blowing and if it did, they report back how their baby runs with a new pump, engine, etc, is why we come here. I heard about FTE when I was running into problems with my F150. Saved me a ton money the forum did.
What is strange here is the bad luck with not one but two 6.7L trucks. I would be heading over to get a Govt Motors to buy a one ton. I would prolly would post a sentence or two in that thread about that.
= before kool aid.
= after kool aid. Sorry for hi-jacking your post ricatic, and your experience with your trucks.
Jim
Rick if you are still out there has there been a resolution to your CELs yet? Sorry if I've missed it in the above back and forth...
