Need some advice
Old Nov 17, 2012 | 08:09 PM
IDIpower86's Avatar
IDIpower86
Need some advice
I have a 86 f250 6.9 I just want a little more power out of it I put a Ats turbo and turned up the ip a half of flat is there anything else I can do thats cost effective?
Old Nov 17, 2012 | 08:17 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
do you have an EGT gauge? if so then crank that fuel up more. don't go over 1100 for sustained amount of time though. do you have a boost gauge? if so then what kind of boost do you see? if you have neither of these two gauges then those are a must to buy for your truck now that you have turned the fuel up and have boost going into the engine.
Old Nov 17, 2012 | 08:20 PM
IDIpower86's Avatar
IDIpower86
Ihave a boost gauge and my egt is on its way. And if I just turn it up alot isn't it just gong to waste fuel
Old Nov 17, 2012 | 08:35 PM
IDIpower86's Avatar
IDIpower86
I'm looking to keep my mileage and just get a little more horse power out of it
Old Nov 17, 2012 | 08:45 PM
'94IDITurbo7.3
your right foot is what hurts or helps fuel mpg. as long as you keep your foot in check, you can do what ever you want with your fuel screw and you mpg will stay the same.
Old Nov 17, 2012 | 08:57 PM
IDIpower86's Avatar
IDIpower86
OK but besides that Theres nothing really else you can do
Old Nov 17, 2012 | 09:01 PM
jayro88's Avatar
jayro88
What kind of boost are you running? The easiest thing to do is turn up the boost and fuel. Opening up the exhaust/intake can help. Do you have an intercooler set up?
Old Nov 17, 2012 | 09:02 PM
'94IDITurbo7.3
how many miles on IP and injectors? if they are getting near or are over 150K miles then they are tired and should be replaced. that will gain you some oomph there. adding an intercooler will increase efficiency of the air charge. there is not a lot you can do with out spending some money
Old Nov 17, 2012 | 09:20 PM
IDIpower86's Avatar
IDIpower86
Idk honestly I'm savings up to get the baby moose injection pump but cant really afford injectors right now and no it is not intercooled and I have 3 1/2 straight pipe in it
Old Nov 17, 2012 | 09:52 PM
NMB2's Avatar
NMB2
I can help you with pump and injectors
Old Nov 17, 2012 | 10:00 PM
IDIpower86's Avatar
IDIpower86
Help me do what?
Old Nov 18, 2012 | 02:26 PM
NMB2's Avatar
NMB2
Get them....
Old Nov 19, 2012 | 05:41 AM
IDIpower86's Avatar
IDIpower86
I just found a set of dephi injectors for 105 bucks
2000F250guy
Oct 29, 2011 11:56 AM
urbanagolfer
15
Sep 6, 2010 07:33 PM
wycowboy
Nov 22, 2007 11:48 PM
wycowboy
13
Apr 7, 2005 11:22 PM
yellow73bb
Jan 15, 2004 12:23 AM
