ICP Sensor question
Old Nov 15, 2012 | 05:41 PM
cutlass's Avatar
cutlass
ICP Sensor question
I just got a po476 code when I performed the KOER test on AE. I pulled the wiring from the sensor and yes there's a little oil in there. The engine runs rough at idle like it's missing and it less noticeable at higher RPMs.
When I tried to re-start the engine it took forever get started. I just cranked for about 20 seconds until it started. Even after shutting the engine off and immediately re-starting the crank time is around 10-15 seconds.
Is all of this inter-related to the ICP sensor being bad or is there another issue with my long crank time?
Thanks,
Drake
Old Nov 15, 2012 | 05:55 PM
Tugly's Avatar
Tugly
P0476 is your EBP sensor. Unless you unplugged both of them at the same time and reversed the ICP/EBP connectors, that particular code shouldn't be related to the ICP.
Old Nov 15, 2012 | 06:14 PM
cutlass's Avatar
cutlass
Does oil in the ICP sensor cause long crank times to start or does the EBP sensor failure cause that?
Old Nov 15, 2012 | 06:41 PM
trekbasso's Avatar
trekbasso
Sorry I can't help with all of it, but several months ago one morning my truck almost didn't make it into the driveway after I backed out. Running very rough. I had a lot of oil in the connector, cleaned with electrical cleaner, ran good after. Replaced the sensor two days later. Not very scientific, but hasn't acted up like that since.
The ICP sensor.
Old Nov 15, 2012 | 09:18 PM
cutlass's Avatar
cutlass
So, maybe I should be asking where I should look for the cause of the long crank time to start. Anyone have an idea where I should be looking?
Old Nov 15, 2012 | 10:43 PM
empiretc's Avatar
empiretc
Starter or glowplugs
Old Nov 16, 2012 | 06:00 AM
Tugly's Avatar
Tugly
A good place to "Start" is by clicking that last link in my signature.
Old Nov 16, 2012 | 06:06 AM
trekbasso's Avatar
trekbasso
By the way, that is an awesome link . I printed the diagnostics out in case I have problems on the road.
So, what is it where you are Tug, 4am? Geez your up early.
Old Nov 16, 2012 | 07:57 AM
howellt39's Avatar
howellt39
Mine took a long time to crank, like you describe, after I had evacuated an oil gallery in order to change an injector. I didn't see anywhere in the thread where you had confirmed the level and quality of the oil. Very important for our engines. Doubtful that it's that simple, but the symptoms matched so thought I'd let you know. Good luck.
Old Nov 16, 2012 | 07:58 AM
cutlass's Avatar
cutlass
I tried to rep you on this, but the rep police are out! Absolutely awesome find!!! Thanks Tugly!
-Drake
Old Nov 16, 2012 | 03:08 PM
Tugly's Avatar
Tugly
Originally Posted by trekbasso
Geez your up early.
I'm one of those old farts who can't stay up past 7-8 PM
I stumbled onto that shortly after it went online and it's just too good to not have a permanent link.
cvfcems
May 3, 2013 11:15 AM
TNT in Round Rock
Jan 24, 2012 03:58 PM
mike L
Feb 24, 2010 03:26 AM
Chistoso
22
Sep 18, 2009 10:13 PM
ballbandit
Apr 12, 2007 07:41 PM
