need some trans advice
Old Nov 9, 2012 | 10:39 PM
hondamxr's Avatar
hondamxr
I have the 2000 f350 SD and the OD went out about 2 months ago.. I was able to drive it in drive with no problems until the other day. I was going about 50mph and all the sudden the truck ;lost it's momentum and had no drive left. I pulled the transfer case and tranny and took the oil pan off. What should the next step be?? any Ideas on what could have gone out
Old Nov 9, 2012 | 10:42 PM
1fixitman's Avatar
1fixitman
People usually purchase a upgraded valve body from John Woods or Brian's Truck Stop or BTS. If BTS rebuilds it.....they will give a lifetime warranty and it is close to 5000$ Sorry to hear about your issue. Where are you located. John Woods is mostly West coast and BTS is East coast.
Old Nov 10, 2012 | 07:40 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Something mechanical broke inside the trans. If it were still in the truck I could help diagnose what broke, but no matter what it is the answer is the same. It has to be rebuilt or replaced. A new valve body isn't going to help at all.
Old Nov 10, 2012 | 08:00 AM
Tugly's Avatar
Tugly
BTS is top of the list, but the local stealership can put in an HD4R100 that is no slouch for less money: $3500 (tranny only) after the core return.
Old Nov 10, 2012 | 09:07 AM
hondamxr's Avatar
hondamxr
[QUOTE=Mark Kovalsky;12469311]Something mechanical broke inside the trans. If it were still in the truck I could help diagnose what broke, but no matter what it is the answer is the same. It has to be rebuilt or replaced. A new valve body isn't going to help at all.[/
what info do you need. I can. probably give the answerQUOTE]
Old Nov 10, 2012 | 12:03 PM
Mark Kovalsky
At idle how much pressure is at the test port? How much pressure in drive at stall speed?
Old Nov 10, 2012 | 03:00 PM
hondamxr's Avatar
hondamxr
I see your point...when I put it in gear now there is kinda a a rubbing noise but obviously the truck dpesnt mpve. is there a way to check anything woth it out?
Old Nov 10, 2012 | 03:10 PM
Mark Kovalsky
Yes, tear the trans down. It should be obvious what's wrong.
Diagnosing this in the truck would have really been an academic question anyway. No matter what the diagnosis was the solution is take the trans out, tear it down, and rebuild it. Something mechanical broke inside. Does it really matter WHAT broke before the teardown?
Old Nov 10, 2012 | 04:17 PM
hondamxr's Avatar
hondamxr
Old Nov 10, 2012 | 04:19 PM
hondamxr's Avatar
hondamxr
one more thing..there was alot of metal shavingson the magnet when I drained it?
Old Nov 10, 2012 | 04:28 PM
UP_There's Avatar
UP_There
start saving your pennies.......Definitely upgrade as much as you can afford with a new transmission. It's money well spent if you plan on keeping the truck!
Old Nov 10, 2012 | 05:04 PM
Mark Kovalsky
Tear it down and find out what failed. What is the point of trying to guess what broke?
Old Nov 13, 2012 | 10:24 AM
hondamxr's Avatar
hondamxr
gonna start tearing it down today...Is it possiblee to do the rebuild on my own with regular tools or will I need to have specialty tools? Is there a certain transmission book I can buy that would be beneficial?
Old Nov 13, 2012 | 03:08 PM
Mark Kovalsky
Buy a manual at www.atsg.com. You can do it without special tools, but they make it easier.
Old Nov 13, 2012 | 04:34 PM
trekbasso's Avatar
trekbasso
Good luck!!
caedo
Jan 31, 2013 06:49 AM
kawika
29
Oct 21, 2010 04:28 PM
tholt34
Dec 2, 2007 12:29 AM
78rocket
Sep 14, 2006 06:26 PM
Uzumati
Jul 26, 2006 11:29 AM
