What else does the timing advance temp guage effect?
So I need to replace my timing advance/cold start sensor. It is still sending voltage to the plunger by the throttle even after the engine is at operating temp. For now I unplugged the plunger (easy to get at), is anything else effected by a faulty temp switch? Does it send voltage to anything else that would effect performance/mileage if I leave it as is for now?
Yes it advances the timing in the injector pump. But if you unplug the harness from the temp sensor (located by the therostat housing) you should be all right.
Okay, thanks. I will unplug it there. It is in a van...hopefully I can reach it without removing the doghouse. What type of adverse effects would I see form the advanced IP timing? Does it advance it past the point of being helpful for performance?
i disagree john. you can do it all from the front.
i played with mine quite a bit recently, and pulling wires on and off can easily be done by reaching around the thermostat housing.
for actually replacing the sensor, i used a 15/16" deep socket on 1/2 drive to remove it, and a 7/8" open end wrench to install it. it fits the 7/8 properly, but the larger socket makes for easier access around the thermostat housing. also, for installing it with the wrench, i loosened the air cleaner and slid it to the rear a few inches to get enough swing room for the wrench. its really pretty easy, just don't try to replace that sensor on a hot engine, as it does go into the coolant.
oh yeah, that snorkel thingy - i picked up a stock one at the junkyard a couple months ago but never got around to putting it on. without it, the job isn't bad at all.
Might be possible, can't remember. Think my new cold air snorkel is in my way.
I was just looking at it. The cold air tube is in the way. If it wasn't there I could reach behind the T-stat housing and get to the plug. Could I just pull the 2 leads off the IP instead of pulling it off the temp sensor? It looks like the harness comes up and splits 3 different ways.....1 to the plunger for the throttle and 2 to the IP. That would be the easiest and only require me to remove the doghouse and air cleaner once (when the sensor arrives).......yes I can be lazy sometimes. If not, it looks like the front seat and doghouse are coming out tomorrow.
yes, you can do it that way. my understanding of the wiring is as follows: the ONE wire entering this group goes directly to the fuel shutoff solenoid, but you notice two wires on that plug. the other goes back to the temp sensor, from which it goes to both the HPCA solenoid and the high idle speed solenoid.
therefore, unplugging those two components is equal to unplugging the sensor. i drove with mine unplugged for months before raiding a couple junkyard trucks for the sensors.
are you getting your sensor from the junkyard, dealership, or somewhere else that nobody knows about?
Okay, just want to make sure I understand you. There are 3 plugs that come out of the wire bundle. One goes to the plunger at the throttle body. The 2 others goto the IP. The one closest to the front of the IP has 2 wires. This is the for the fuel shut-off. I want to leave that one alone (disconnecting would shut the fuel off). The 2nd plug, which is the one that attached further to the back of the IP, is the one that controls the IP timing cold advance. It only has one wire going to it.
So to get rid of the cold advance, since my sensor is bad, I would unplug the single wire connector at the throttle plunger and the single wire connector that attaches further back on the IP. I would leave the 2 wire connector (towards the front of the IP) hooked up. If I took this one off it would not allow any fuel in and the van would not run.
Am I correct?
I found a thread on here that had a link to a place that sells them. I have not contacted them yet to see if they ares still avialable. If will try and find a god one at a junkyard or from a forum member.
your statement is correct. and to clarify here, all connections here are "1 pin" connections, though some of those have 2 wires crimped together into the one connection. you may either unplug both the throttle plunger and the cold advance solenoid, OR unplug the temp sensor if you can reach it.
when i was first playing with mine, i unplugged things with the engine running, and quickly found out that the connection on the front of the pump is the fuel shutoff.
as for the place that might sell them, if they're still available it might be good to post a link here for anyone who searches and finds this thread later
Yes, they are all one pin connectore. Once I can verify they are actually avialable I will post the link. Thanks for your help.
