2.9 Ignition Timing
Old Jan 13, 2006 | 11:54 AM
SShank42's Avatar
SShank42
2.9 Ignition Timing
I have a 87 2.9. When I timed it last time I used a light plus a vacuum guage. I set the timing with the light and check with guage. According to the guage the timing was slow, so I set the timing to match the guage. After this I rechecked with the light and the light showed about 16 degrees. Vehichle seems to run okay but I am only getting 15 mpg's. It has new plugs, wires, cap, engine temp. sensor, and air charge sensor. I was wondering what is the correct to set the timing. Guage or light. If I set it back to 10 degrees will I get better MPG's. I do remove the SPOUT. Thanks.
Old Jan 13, 2006 | 02:31 PM
dernst's Avatar
dernst
You will get the best mileage if you remove the SPOUT and set to 10* BTDC.
ReugularGuyBob
13
Jun 6, 2015 03:53 PM
arockyway2go
Jun 2, 2014 12:01 AM
tchile
Bronco II
Feb 9, 2011 08:32 PM
1970f2504x4
Sep 22, 2004 04:29 PM
CrazyFazy
Bronco II
Mar 1, 2004 07:26 PM
