Effii gets rebuilt
Started turning the aluminium blanks for the 1 inch body lift.
That's it for this week and there won't be much next week as I've got a dingo for the week and need to do several things around the house with it.
Back in about 10 days with more from the rebuild.
Ended up doing about ten times more than originally planned.
So completed the body lift blocks and radiator hose adapters. Top radiator hose adapter also has thermo fan switch.
So lot's of other little things to be done but would really like to get the top coat on the cab so I can put it on the chassis and then have some room for changing over the diffs etc.
Started sorting the chassis wiring loom. The original is from a fuel injected chassis so has the wiring for in tank pumps, ecu, etc. So I'll be using some of those for other things.
Rewrapped the chassis loom with dry vinyl tape. Much neater. Changed some of the wiring so that the fuel selector switch on the dash controls the fuel selector. This then switches the fuel sender to gauge.
Other changes include adding wiring for rear view camera, electric fuel pump, extra power wire to rear of chassis.
Reinstalled the loom in the chassis and connected everything up. Need to wait until the cab is on to test it all.
Completed connecting the fuel lines to the mid tank, air vent connector added to top as well.
Setup the power steering/hydraboost cooler and filter.
Started building the exhaust, I'm only doing back to where the muffler will be for now, as I'll take it to the local exhaust shop for the muffler and tail pipe.
Exhaust will be 2 1/4" from original engine pipes to merge collector to 3" to muffler and 3" tail pipe.
Got some painting done as the rain cleared for two days and it was warm.
Painted the firewall completely, and one coat over the rest of the cab.
Finished the exhaust engine pipes, painted with heatproof paint, I'm going to wrap these with heat shield as well.
A slight change with this in that I can get an appropriate muffler and fit it myself then I only have to take it to the exhaust shop to have a tail pipe made up.
I was actually not looking forward to this job as previous experience trying to bulld exhausts was painful. However three mandrel bends, three straight couplers a length of straight pipe with a flare on the end, one merge collector, one flange and one egt bung, it all came together easily. Needless to say the fact that I'm working without the cab on and not having to do the welding from underneath made a big difference.
Put the cab on the chassis. Although I'll probably take it off again as I want to tidy up a few things and it's easier with the cab off.
Plenty of clearance on the left hand side, although I'm going to move the fuel return line.
not quite as much on the right hand side, although its only near the reinforcement of the firewall where the clearance comes down to about 15mm.
lots of clearance if I decide to fit a turbo.
However without a 1 inch body lift it would be really marginal all round and I'd suggest you probably need to do some massaging of the firewall.
Swapped the transfer case for the original one. Originally I was going to have a new rear drive shaft made up but the angles really don't need the double cardan joint so going with the long slip yoke unit that was in there. It's exactly the same transfer case just with a slip yoke instead of a flange on the rear output.
Also something I just noticed from the last photo and I had not mentioned elsewere, wherever Ford (and others) have used self tapping screws directly into bare metal I've put a rivnut. Mostly these are 3/6" as they tend to be for trim pieces, some are 1/4" like around the trans cover in the interior and around the steering shaft mount (you can see the ends of them in the photo). This way you don't end up with stripped holes with larger and larger screws to hold whatever it is in place. All up there's about 60 rivnuts in the cab. I'll be using these anywhere else needed.
Hypermax
The up pipes come up over the gearbox/bellhousing.
There's about six inches of clearance there.
But also looking at the side winder installation instructions it would appear that there is enough room as well. I've removed the ear on the bell housing as per these instructions so it does not have to be done with the cab on later.
The bottom lip of the firewall above the transmission is just below the level of the rocker covers.
I'll see if I can get some other photos that show this clearer, the angle at the moment is quite deceptive.
Smart move rectifying the bell housing now,coming along nice ross
