help installing ignition bezel
Old Oct 31, 2012 | 04:45 PM
tip49's Avatar
tip49
tried to no avail to install the bezel on my 1950 truck. I even bought an after market one, but can't get it to seat on the ignition .
Any install suggestions appreciated; I would think it should just press into place with possible twist to seat it ?
Tom
Old Oct 31, 2012 | 05:43 PM
bobj49f2's Avatar
bobj49f2
Yes, if I remember correctly once the main part of the switch is through the dash the bezel just twists on. It's been a while since I installed mine so I might be a little foggy on the installation procedure.
Old Oct 31, 2012 | 06:42 PM
tip49's Avatar
tip49
Thanks Bob
I thought it might be the spring inside the bezel but I bought another and have the same issue
Old Oct 31, 2012 | 06:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
See if the tangs mesh correctly with it off the dash. You may have gotten a 51-52 switch, which are different.
Old Oct 31, 2012 | 07:37 PM
51PanelMan's Avatar
51PanelMan
As far as I know, there are no reproductions of the 48-50 ignition and parts. Only 51-52. So, if you purchased an aftermarket piece, it's for a 51-52.
Old Oct 31, 2012 | 10:44 PM
Kazoo's Avatar
Kazoo
Just installed mine the other day. Pushed on with my thumb it went "click" and thats all there is to it. My switch and bezel are both original equipment.
Old Oct 31, 2012 | 11:28 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
My switch and bezel are probably made in China, and the bezel does not want to twist into place on the switch. It doesn't really fit. It stays in place because of the spring pressure, but I expect it to pop off sometime without notice...
Old Nov 3, 2012 | 08:55 PM
tip49's Avatar
tip49
Original bezel
Have the original ignition and bezel but so far unable to get the bezel to seat prorperly. Also bought aftermarket which states it's for the 48-50, still no luck in getting it to fit properly.
I'll have another go at it this winter.
Tom
DGMFORD
Mar 24, 2015 01:08 PM
mzerega
Feb 15, 2014 02:19 PM
pells49
Oct 29, 2011 10:09 PM
Gary Graham
Apr 27, 2007 06:52 AM
Delzell
Apr 26, 2006 07:18 PM
