ignition bezel mounting question
Old Apr 24, 2007 | 10:10 AM
Gary Graham's Avatar
Gary Graham
I can't seem to figure out how the ignition bezel/ignition switch mounts in the dash of my truck. Is there suppose to be some sort of spacer between the two to compress the spring on the ignition switch?
Old Apr 24, 2007 | 10:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
To remove: Battery cable off..push back of ignition switch towards you, bezel comes off with 1/4 turn.
Between the switch and the dash is an inner mounting plate. (spacer)
Old Apr 24, 2007 | 11:40 AM
Gary Graham
Thanks. I believe I am missing this pspacer. do you know the approx thickness of the spacer?
Old Apr 25, 2007 | 05:02 AM
NumberDummy
All the parts catalog says is: 1 1/4"-diameter. This shouldered spacer was used on ALL trucks from 1961/66.
Old Apr 27, 2007 | 06:52 AM
Gary Graham
spacer between ignition switch and bezel on '66
NPD has a part that is intheir Interior parts catalog. On page 12 they list a mounting plate for a 61-66 part # F10A885-1. They call it an instrument cluster control mounting plate. They do not give any dimensions. Is this the spacer I am missing?
