Weird Voltmeter Reading
Old Oct 30, 2012 | 10:57 AM
JDFan4010's Avatar
JDFan4010
When I get in to start the truck (1990 F250 7.3 n/a) my voltmeter shows 10 volts, after wait to start light goes out, it reads 11 volts. Readings of 1 year old batteries in 12.56 & 12.52 with cables off. After running it it gets up to about 14 volts. It seems fine to start, but I would think it would read 12.5 volts after glow plugs have heated. Do I need to concern myself with this? If so what should I do next?
Thanks,
JDFan4010
Old Oct 30, 2012 | 11:06 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Sounds about right to me, after letting it sit, what do the batteries read with cables on before turning the key on?
GPs pull one hell of a load, so the batteries will read low for a sec i would guess. If it starts fine, i wouldnt worry about it.
Old Oct 30, 2012 | 02:13 PM
JDFan4010's Avatar
JDFan4010
OK, I wont mess with it then. Thanks.
Old Oct 30, 2012 | 02:15 PM
SnuffthePunkz's Avatar
SnuffthePunkz
They aren't in a bad zone yet, but it sounds like they are just starting to get tired. Likely in a year or two you may have issues though.
Old Oct 30, 2012 | 02:38 PM
JDFan4010's Avatar
JDFan4010
Snuff- your talking about the batteries right?
Old Oct 30, 2012 | 02:42 PM
SnuffthePunkz
Yeah as hairy said you have nothing to worry about right now. Just keep it in the back of your mind when a couple years down the road comes along and things start acting up to get them tested at a battery shop before you start ripping everything else apart.
Old Oct 31, 2012 | 06:48 AM
hookedondiesel's Avatar
hookedondiesel
Thanks,
JDFan4010
Just curious, when you say "after running" did you mean, with the cables disconnected you were getting 14 volt's, or was that while it was running.
A battery that shows 14 volts "on it's own", will not last long, it's cell's are shorting.
Old Oct 31, 2012 | 08:14 AM
JDFan4010's Avatar
JDFan4010
Batteries connected, 14 was reading off voltmeter on truck gauge.
rscamaro305
Jan 26, 2012 03:39 PM
goosehunta
Apr 15, 2011 05:31 PM
njstevens
Aug 28, 2010 11:46 AM
MPlayer
Aug 5, 2008 09:36 PM
Eric326
Jan 25, 2008 10:39 AM
