Another no start
Old Jan 25, 2012 | 10:31 AM
rscamaro305's Avatar
rscamaro305
Another no start
Hi everyone. I am fighting a crank no start on my 2001 Power stroke. It used to start fine if it was plugged in for about 2 hours and as it got colder (single digits and below) this stopped helping. I went out yesterday to work on it and I found the GPR had 10.5 volts on the output side when key is on. and the glow plugs read to a ohm each. I was only able to test the passenger side because of time and coldness (about -10). I also hooked up my inductive ammeter and found that the glow plugs when switched on were pulling a max of 100 amps and after about 20 seconds they pulled about 75 amps. My simple Ohms law tells me that at 1 ohm they should pull about 126 amps at a battery resting voltage of 12.6. Is any of this an indicator of a faulty glow plug system?? Any other checks you guys reccomend?? Thanks.
Old Jan 25, 2012 | 10:55 AM
PwerStroke99's Avatar
PwerStroke99
have you checked both batteries to make sure they are good?
Old Jan 25, 2012 | 11:31 AM
PaysonPSD's Avatar
PaysonPSD
What voltage do you see at the always hot GPR terminal?
If you are only seeing 10.5 volts with key on then when you go to start the voltage will fall below the 10.5 required for the IDM to operate the injector solenoids and that will cause a no start. You need 10.5 volts WHILE cranking.
Old Jan 25, 2012 | 05:14 PM
2000ford7.3's Avatar
2000ford7.3
Weak batteries!!!!! It will crank but will not start! Try trickle charging your batteries separately at 2 amps. If this does not work. New Batteries!
Old Jan 25, 2012 | 09:50 PM
rscamaro305
I was at 12.6 at the always hot terminal.
I didn't check cranking voltage at the batteries. Obviously if the glow plugs pull them down to 10.5 then there isn't much left for everything else. I need to look at that. I didn't think much about it cause I replaced the batteries in September in preparation for winter and I charged them before I tested these things.
Old Jan 26, 2012 | 03:39 PM
2000ford7.3
Wow! Sorry man. I dont have any idea unless your alternator isnt charging and has been killing your batteries.
Walleye Hunter
42
Feb 1, 2019 01:43 PM
DieselVol
Sep 13, 2012 05:33 PM
goosehunta
Apr 15, 2011 05:31 PM
dyhrdford
Dec 4, 2009 05:03 PM
MPlayer
Aug 5, 2008 09:36 PM
