Low Voltage When Starting
Old Aug 2, 2008 | 03:00 PM
MPlayer's Avatar
MPlayer
Hey guys I have quick question. When I leave my PSD sitting for a couple of days it will not start like the batteries are dead. I checked the batteries and they both show 12.2 VDC each. I did unhook the cables to isolate them. They are about two years old. When I turn the key on the volt guage goesdown to about the N in normal but then as the glow plugs are heating up the needle will fall all they way to the left. When I turn the key back off and check the voltage at the batteries (cables hooked up) it reads 12.0VDC. Would this indicate the batteries are bad? IF I put the charger on them it will start. Then it will start fine for about a day or two but if it sits for a couple days this happens. I'm thinking the batteries.
Thanks
Old Aug 2, 2008 | 03:08 PM
884x4broncoII's Avatar
884x4broncoII
sounds like bad batterys to me.
Old Aug 2, 2008 | 03:37 PM
kawa's Avatar
kawa
You need to "Load Test" the battery's. Most Auto Parts will do it for you for free.
Rog
Old Aug 2, 2008 | 03:43 PM
MPlayer's Avatar
MPlayer
That is my next step as soon as my wife comes home with the other truck. I'm guessing the batteries are bad and the glow plugs are drawing more amperage than the batteries can provide. What do you think?
Thanks for the help. I just wanted to get someone elses thoughts on it before I head into town.
Old Aug 4, 2008 | 09:17 PM
MPlayer's Avatar
MPlayer
Yep, both batteries were bad. Replaced them now it starts like a chmp again. Thanks Guys!
Old Aug 4, 2008 | 09:45 PM
c00nhunterjoe's Avatar
c00nhunterjoe
glad to see an easy repair!
Old Aug 5, 2008 | 09:36 PM
MPlayer's Avatar
MPlayer
Yah it wasn't bad. Thanks, I have learned so much here.
