Cab&Chassis flat bed mounting
Old Oct 29, 2012 | 08:16 PM
6.9 diesel nut's Avatar
6.9 diesel nut
A couple weeks ago, I scored a used flat bed for $275 bucks. It's 9' long. I believe it to be a Knapheide westerner. I and my dad are trying to figure out how to attach it. We're going to use oak boards for spacing, but how to attach it to the frame has got us stumped. How did y'all do yours?
Old Oct 29, 2012 | 11:31 PM
91dirtydiesel's Avatar
91dirtydiesel
I liked how your truck looked with that dually bed on there. Sorry cant help with flatbed part
Old Oct 30, 2012 | 12:39 AM
oldblue89's Avatar
oldblue89
X2 on what dirty said, was it rotted?
How did the middle bed look:
88x10ft steel flatbed 34 in sub frame
I need one for my cab and chassis IDI
Old Oct 30, 2012 | 02:05 AM
kc0stp's Avatar
kc0stp
Alright found Fords answer for the newer trucks, dont see why it wouldnt work on ours as well (though Im going to add a 3rd bracket to each side even with gooseneck hitch) my only worry is if it allows enough frame flex so we dont run the risk of cracking the frame.
Clicky
Old Oct 30, 2012 | 07:47 AM
6.9 diesel nut
LOL! How did ya figure out that was the guy I bought my bed from? The middle one was very nice. It lacked lights, but was in much better shape than mine. I think he was asking $500. As for my pickup bed, It was so banged up, it just didn't work for what I needed. One of the bed sides had a busted weld, there is several cracks in the floor, there's a big hole in the middle that isn't in the center of the bed, and it didn't fit my truck well. Thanks for the article.
Old Oct 30, 2012 | 11:38 AM
oldblue89's Avatar
oldblue89
Hah, photographic memory I guess, I remember seeing the ad. I won't be back in VA for another month, hopefully I'll get there in time to go check that middle bed out, sounds exactly like what I'm looking for.
To answer your original question, the standard way to mount a flatbed seems to be with big U Bolts (a larger version of what our springs bolt on the axle with) - usually there will also be a spot where the bed is bolted to the frame, of course since that was off a C&C truck you might need to make special brackets. A lot of times you will see wood as a spacer between with bed and frame.
Old Oct 30, 2012 | 11:43 AM
jgoodman6891's Avatar
jgoodman6891
All of the flatbeds Ive looked at were either welded on of had square ubolts holding the frames together. If/when I pull the dump bed off my '85, Im more than likely going to mount it like the military mounts the M109 box to the frame. Piece of angle on the truck frame & a matching piece on the box. Bolt through them that has a spring between the nut/washer & one of the angles.
I looked real quick & I dont have a picture of it nor found one online. This is a truck like my friend has that I found out about the sprung mounts.
Old Oct 30, 2012 | 12:21 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Thats how i would mount it if you see alot of flex, if not i would just bolt the flatbed to the frame and call it good. The U-bolts would work too.
If the flatbed is built hell for stout, and it solid to the frame, especially if welded, it can crack the frame at the spring hangers or right in front of the bed. Honestly idk about the spring hangers, i was told, but ive seen them crack in front of the bed. Welding compounds the problem even further as it makes the frame brittle.
FWIW i liked the way the dually bed looked too
Old Oct 30, 2012 | 01:15 PM
6.9 diesel nut
OK thanks. I'll probably go with the U bolt idea, if I can find them. Hate to disappoint ya guys, but the flatbed is going to stay I think. Got to get more use out of the truck for the farm, like hauling animals, hay, and other stuff. The versatility of the flatbed and custom sides, will be nice. The pickup box just didn't work.
Old Oct 30, 2012 | 01:24 PM
hairyboxnoogle
Oh trust me, if my truck were my work truck id have a utility box or flatbed on it in minutes. The flatbed looks tough on there anyway.
Old Oct 30, 2012 | 03:47 PM
6.9 diesel nut
Thanks. Yeah, I thought it looked good. At least the truck will ride nicer.
Old Oct 30, 2012 | 05:23 PM
tecgod13's Avatar
tecgod13
Any spring shop should be able to bend up whatever sized U-bolts you're looking for. Just look for a local spring shop, or heavy duty truck shop. Bring in your dimensions and they can bend it while you wait. (at least thats what I did when I was replacing my rear springs).
Old Oct 30, 2012 | 07:45 PM
greywynd's Avatar
greywynd
Don't get too worried about welding on these and stiffening the frames. My dually with flatbed dump has welds all over the original frame because it was rotting out in a couple places, and I then built a 2x3 rectangular tube subframe for the dump bed to sit on, that is also welded solid to the frame. No signs of cracks yet, and that truck has likely dumped thousands of tons of material since I did it. The job I just finished up it hauled about 600 tons of material alone. (It was shuttling it 1/8 to 1/2 mile from where the dump trucks could get to.)
I even did the 'no-no' of vertical welds on the upright section of the frame in 3 places. The only issue I have with it is now the cross member for the rear cab mounts is rotting out, and the cab is twisting due to it, lol!!
Old Oct 31, 2012 | 08:32 AM
6.9 diesel nut
OK. Still leaning towards the Ubolts.
Harrier
82
Jul 28, 2023 03:50 PM
dustyroad
Jun 10, 2018 09:08 AM
Cougar54
18
Sep 12, 2016 06:36 AM
RedJunkie
16
Apr 19, 2012 04:34 PM
mike potts
Jul 24, 2009 03:47 AM
