battery voltage at startup
Old Apr 14, 2011 | 09:08 PM
goosehunta's Avatar
goosehunta
I have a sct tcx which is kinda like a scan gauge+programer. when i first turn key on and waiting on the wait to start light i am showing 11.5ish volts. this is while the glow plugs are warming up and fuel pump is running and whatever else is on. it does take a few seconds of the starter turning for the truck to start but when its cool outside around 35f it starts faster...??? that dont make sence to me. do you guys think i need to start plaining to replace the batteries?
thanks for your input.
Old Apr 14, 2011 | 09:30 PM
BLADE35's Avatar
BLADE35
I would load test the batts individuly
Old Apr 14, 2011 | 10:54 PM
dchamberlain's Avatar
dchamberlain
The glow plugs draw 10 to 12 amps each. 11.5 volts with the key on waiting for the wait to start light to go out isn't bad at all.
It still wouldn't hurt to disconnect each battery, charge them good, let them sit for awhile and then load test them.
Old Apr 14, 2011 | 11:33 PM
mhoefer's Avatar
mhoefer
I run 12.8 waiting to start at 70 f, about 12.7 at -25 f. You have weak batts, load test individually. Replace in sets, how old are they?
Old Apr 15, 2011 | 08:29 AM
goosehunta's Avatar
goosehunta
Im not sure how old they are. Have not looked for a date on them yet and have not tested them yet. I have only had the truck 2 months
Old Apr 15, 2011 | 04:25 PM
bpounds's Avatar
bpounds
That doesn't sound right to me. Mine is in the 11's when the glow plugs are hot, even after starting, even with brand new batteries, until the alternator turns on. Always has been.
Old Apr 15, 2011 | 05:31 PM
steelhead2's Avatar
steelhead2
I'm at 11.8 when the plugs are on,after about 2 min it'll go to 13.8-14.0. Been that way as long as I can remember.
ZerosFate
Oct 18, 2014 05:41 AM
Lilryan
Nov 29, 2012 08:59 AM
lexasgs400
Sep 10, 2007 11:39 AM
wtmac
Mar 31, 2004 04:30 PM
