Batteries
Old Oct 29, 2012 | 09:00 AM
  #31
Whiteline's Avatar
Whiteline
What happens to a battery that sits on the ground?
Old Oct 29, 2012 | 09:31 AM
  #32
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
It can discharge...
Old Oct 29, 2012 | 09:32 AM
  #33
Hdslider's Avatar
Hdslider
It kills them. That is why they tell you never put it on the ground or concrete. But to put on a block of wood.
Old Oct 29, 2012 | 09:33 AM
  #34
Whiteline's Avatar
Whiteline
Got it, thanks.
  #35
Tuxedo Scorpion
It "grounds" the battery..and yes kills them.
Old Oct 29, 2012 | 09:58 AM
  #36
los341's Avatar
los341
Ok sorry I can't take it any longer. Sitting a battery on the ground does not "ground" it. As a matter of fact, sitting a battery on the ground, vs. on a shelf, makes no difference on how long the battery will last. I don't care if it's concrete, wood, linoleum, carpet, or dirt!
If that optima battery died after sitting in a car in the cold for a few days, it was probably due to either a defective battery, or an unknown parasitic load, such as leaving a phone charger in the cig. lighter socket. Running any battery completely dead (i.e. to zero volts) will ruin it... even the best deep-cycles can't take an absolute discharge more than once or twice.
Carl
Old Oct 29, 2012 | 10:10 AM
  #37
darren32's Avatar
darren32
Snopes says its false......... but I still put mine on wood
snopes.com: Do Cement Floors Ruin Car Batteries?
Old Oct 29, 2012 | 10:30 AM
  #38
SavageNFS's Avatar
SavageNFS
I'm with snopes.
Old Oct 29, 2012 | 12:13 PM
  #39
PHXDiesel's Avatar
PHXDiesel
Another thumbs up for the Die Hard Platinums. I had a battery die in my '08 shortly after buying it. I replaced both batteries with the Die Hards and have not had an issue. Just because I'm curious about longevity, when I bought the 2011 I had Ford take out the factory batteries and put in my old Die Hards. They are still running strong.
Old Oct 29, 2012 | 12:15 PM
  #40
Tuxedo Scorpion
I did the same thing when I traded in my 6.4 for the 6.7!!
Old Oct 29, 2012 | 02:24 PM
  #41
FONRDAY's Avatar
FONRDAY
the die hard platinum is the same exact battery as the odesy but half the cost
Old Oct 29, 2012 | 02:27 PM
  #42
FONRDAY's Avatar
FONRDAY
I wish I did that but service manager said it might void warranty I was so dumb for not switching them
arcticatdan
Jul 26, 2018 06:48 PM
Moby Dick
16
Jul 17, 2013 11:23 AM
Bender99
27
Nov 25, 2010 09:43 AM
Pikachu
Feb 10, 2010 10:27 AM
74baja
May 14, 2009 04:06 PM
