Batteries
Old Oct 25, 2012 | 04:32 PM
Whiteline's Avatar
Whiteline
Batteries
I've got a 2011 with batteries that are leaking, I don't really want to spend the money on new ones but I don't want everything corroded either.
What are your recommendations on new batteries? I live in Manitoba so I want good batteries for when winter gets nasty.
Thanks in advance...
Old Oct 25, 2012 | 04:34 PM
strokin83's Avatar
strokin83
The best batteries I've ever had are the Die Hard Platinums. But they were spendy. Is your truck out of warranty already? If not I'd get some freebies from Ford.
Old Oct 25, 2012 | 05:54 PM
madsonp's Avatar
madsonp
Are they leaking, or could they be over charging and boiling out some of the acid ?
Old Oct 25, 2012 | 05:58 PM
kper05's Avatar
kper05
Both of mine have been leaking for over a year.
Nothing bad such as acid everywhere but you can see the dust has been disturbed around the cells for 1-2 inches.
My dealer told me there was no way they would be able to get FoMoCo to sign off on two new ones.
Old Oct 25, 2012 | 08:23 PM
Olds69442's Avatar
Olds69442
DieHard AGM batteries are an option
Old Oct 25, 2012 | 09:14 PM
Rick Cargo's Avatar
Rick Cargo
I had my truck get its 30k service yesterday, its 2 1/2 years old and I asked the service advisor about the drivers side battery that was leaking enough to corrode the bracket. Ford wouldn't replace the batteries because the batteries are fine they just leak a little bit during charging. I popped off the bracket and cleaned it up and painted it.
Old Oct 25, 2012 | 10:04 PM
Whiteline's Avatar
Whiteline
The truck is only 1 1/2 years old but I've put on 137,000 km (85,000 mi) so the warranty is gone. I brought it up with them anyway and they just tried to sell me some Ford batteries, I think I'll look at something else, I see 1st hand how long those last.
The brackets are corroded already so that's a good idea to clean them up and repaint.
Thanks for the ideas, I'll look into the Die Hards.
Old Oct 26, 2012 | 06:58 AM
720Deere's Avatar
720Deere
The batteries are probably not actually leaking. Just about every Powerstroke that I have come in contact with boils at least one of the batteries over during charging. New batteries unless they are AGM will not fix the problem permanently. I periodically clean the batteries with baking soda and then spray Fluid-Film on anything metal in the area to prevent corrosion.
Old Oct 26, 2012 | 07:37 AM
darren32's Avatar
darren32
I put odyssey 65-PC1750T's in mine. A lot to do with the sterio but also because winter is coming up. Only had them a couple of months but they come highly recommended. Pricey tho.......
Old Oct 26, 2012 | 07:45 AM
Hdslider's Avatar
Hdslider
Now theres some real batts right there. Pricey don't really fit that bill. But well worth it.
Old Oct 26, 2012 | 07:52 AM
darren32's Avatar
darren32
It's all savage's fault, he told me to get them. Up here I think it was right around $750.00 for the 2 of them............
Old Oct 26, 2012 | 07:54 AM
Hdslider's Avatar
Hdslider
They can take some serious amp draw.
Old Oct 26, 2012 | 07:56 AM
darren32's Avatar
darren32
For sure, the lights used to dim when the bass hit with the stock batteries.
Not any more
Old Oct 26, 2012 | 09:34 AM
CascadeF250's Avatar
CascadeF250
Costco Ford diesel batteries are 1000 amp, maintenance free and cost around $180.00 for two in Washington State. I had them in my 2001 and also in my tractor and they worked out well. It doesn't get nearly as cold here as in Montana and Canada.
Old Oct 26, 2012 | 02:03 PM
4stroke's Avatar
4stroke
Optima Deep Cycle has always been the way to go for me.
Pricey but strong and safe.
