Alternator removal
Old Oct 25, 2012 | 12:56 PM
Estam's Avatar
Estam
Noticed the fuseable link very smooth on the out side and from what I read they melt slightly when they blow.
Old Oct 25, 2012 | 05:35 PM
Papa Tiger's Avatar
Papa Tiger
You say the wire is open with a VOM set on ohm's? Check on each side of the fuse (Around it) to see if it passes current/reads little ohm's or is open reading infinite ohms. If it is good seal your test spots back up.
Old Oct 26, 2012 | 09:31 AM
Estam's Avatar
Estam
Checked each side of fuseable link and found it ok. Cut back the heat shrink where the wires join to find this. Made in Mexico.
http://i1224.photobucket.com/albums/...13Oxidized.jpg
http://i1224.photobucket.com/albums/...m/15Mexico.jpg
Old Oct 26, 2012 | 11:25 AM
Papa Tiger's Avatar
Papa Tiger
Yup corrosion is such a killer in wire harnesses and fuse boxes. Good find. I would start another thread to identify this and post the picture. No one suspects this of happening until they see it real. I can't imagine how much people spend/suffer from these problems in older salt states. This happens to all equipment, wipes out complete wire harnesses. Thanks for the pictures. LOL
Old Oct 27, 2012 | 06:00 PM
Diamond-X's Avatar
Diamond-X
I ran another new wire from the rear of the alternator to the big link (is that what you calld it?) due to corrosion on my V-10 204,500 mile Ex. I'm guessing it's a fairly common problem.
blinkerf150
Mar 16, 2021 09:35 AM
Tomboy
Dec 9, 2012 04:49 PM
Auburn56
Jul 13, 2012 06:58 PM
His/Hers 6.0s
Apr 6, 2010 09:10 PM
superdutydawg
Mar 11, 2010 01:19 PM
