Alternator Removal:
Old Apr 6, 2010 | 05:00 PM
His/Hers 6.0s's Avatar
His/Hers 6.0s
Alternator Removal:
I'm doing my EGR delete, but the alternator is kickin' my butt!
What's the trick to getting the connector with the green and orange wire off of the alternator? I'm squezzing and pulling up to no avail, and once again afraid I'm going to break something!
Old Apr 6, 2010 | 05:05 PM
utjer's Avatar
utjer
It isn't bolted down with a nut on a post? If I remember right when I changed my alternator out this was how mine was.
Old Apr 6, 2010 | 05:07 PM
His/Hers 6.0s
Alternator Removal
Yea I got the positive lead off, but it's the other connector.
Old Apr 6, 2010 | 08:09 PM
dschuffert's Avatar
dschuffert
I just did my EGR delete last weekend. I just went out and checked my truck again. I have two connectors on my alternator. The positive feed that is held on by a nut. The other is a push connector with two wires coming out of it. I had to squeeze the connector and then pull up. I just tried it again and it came out without issue.
Old Apr 6, 2010 | 08:32 PM
ehgeeray's Avatar
ehgeeray
There must be something wrong with the connector... It comes off really easily normally.
Old Apr 6, 2010 | 08:59 PM
His/Hers 6.0s
Alternator removal.
I got it. Thanks guys. Now if I could just get the bolts off of my "up pipe". :-((
Old Apr 6, 2010 | 09:03 PM
dschuffert's Avatar
dschuffert
I suspect you are referring to the passenger side up pipe. I ended up using a couple long extensions and unbolted it in minutes. The same for putting it back on (once the bolt and nut is started). The first time I took it off it took me hours.
Old Apr 6, 2010 | 09:10 PM
His/Hers 6.0s
I may have rounded one of the bolt heads. Thinking about getting in there with a dremel and cutting them off.
coalnation
Large Truck
Aug 31, 2014 10:02 PM
thejefe
Sep 17, 2012 06:24 AM
Clint S
1997 - 2003 F150
Feb 4, 2010 10:43 AM
goldsmje
Sep 17, 2009 08:44 PM
switchback
Electrical Systems/Wiring
Dec 1, 2003 10:11 PM
