1993 F-150 4.9l alternator removal help
I discovered that my alternator wasn't charging, so I attempted to remove it today after work. I got the belt off, and I was even able to remove both the top and bottom bolts from the bracket. Now the alternator pivots on the bottom, but it won't come out. Is there another bolt I need to remove, or is there some other trick to getting it off of the bracket? It's difficult to see down where the alternator is still attached.
The Haynes wasn't much help either. It pretty much just says "take it out."
Thanks for any info.
I was able to remove it last night. The first time I wasn't able to see that the alternator was not pivoting on a sleeve like I originally thought.
I ended up purchasing a remanned alternator instead of just replacing the bushings. The reman included a new battery wire harness that they stated "MUST BE USED TO REPLACE THE OLD ONE." They warned of bad things like fire because the factory harness "wears out." It didn't look bad at all to me. Are all remanufactured alternators including these nowadays?
I stress Fire Prone
You missed the perfect opportunity to upgrade to a 3G.
The most common vehicles that use a 3G that fits our trucks are:
(1994-95) Ford Mustang 5.0L
(1994-00) Ford Mustang 3.8L
(1994-97) Ford Thunderbird, Mercury Cougar 3.8L
(1990-95) Ford Taurus, Mercury Sable 3.8L
(1993-99) Ford Taurus, Mercury Sable 3.0L
(1995-98) Ford Windstar 3.8L & 3.0L
Plenty of threads on the swap and what is needed.
If you haven't already done so I highly recommend you load the crap out of the alternator bolts with never seize when reinstalling them. I just went through removing my stock alternator and ended up busting the alternator/air pump bracket because the alternator bolt was completely seized in the bracket.
I haven't finished the installation, and yes, I am definitely going to be putting some anti-seize on the bolts. The lower bolt is corroded and rusty and was difficult to remove. I think first I'll go over it with a wire brush attachment on the drill, coat it with some PBlaster and then put anti-seize on the bolts. The new alternator came with a new bolt for the top mounting bung.
How did you end up getting it out?
86f250XLT-4x4
04-11-2013 09:27 PM
Tomboy
12-09-2012 04:49 PM
JoeTaco1
06-21-2010 09:06 PM
