Alternator plug in connectors?
Old Jul 12, 2012 | 05:25 PM
Auburn56's Avatar
Auburn56
An easy one for you, I am installing a new alternator, the harness has 2 plug in connectors and one spade connector. The alternator on the other hand has studs and nuts for the connectors, what am i missing?
Old Jul 12, 2012 | 08:29 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
The correct alternator?
I'm sure with a wiring diagram and some ring terminals it can be made to work. What year is the vehicle?
Old Jul 12, 2012 | 09:38 PM
Auburn56's Avatar
Auburn56
plug in connectors
The vehicle is a 1981 F100, 300 6, non ac engine. the alternator has regular posts and nuts for the connections but my harness has ring type connectors with red and black covers and then a black ground wire with a stadard ring connector. Did they make different alternator connectors during those years?
Old Jul 12, 2012 | 09:50 PM
ctubutis's Avatar
ctubutis
Someplace in the mid-80s they went to Generation 2 alternators (aka 2G). I think these have built-in regulators but, in any case, the connectors are entirely different.
A few years later, they went to 3G.
A 1981 truck (I have one myself) uses a 1G alternator, I think the sizes available were 40A, 60A and 70A.
Old Jul 12, 2012 | 10:02 PM
Auburn56's Avatar
Auburn56
Does your harness have ring connectors to go over the posts? The easiest thing to do is just cut the connectors off and add ring connectors, but thought i would check here first.
Old Jul 12, 2012 | 11:46 PM
ctubutis's Avatar
ctubutis
Yes, my 1G alternator has ring connectors.
Old Jul 13, 2012 | 06:58 PM
BaronVonAutomatc
If your old alternator had a built-in voltage regulator and new one doesn't you'll need to add one upstream or get the right alternator.
nilzlofgren
Nov 15, 2015 05:24 PM
ConvertedFord
Dec 1, 2012 10:16 PM
sdetweil
Jun 13, 2008 09:10 PM
nowbiteme
1978 - 1996 Big Bronco
Jul 18, 2004 03:51 PM
Mil1ion
Electrical Systems/Wiring
Aug 16, 2002 05:19 PM
