O-ring on oil drain plug? It's a copper crush washer.
The block coolant drains have an o-ring. Not sure on part number.
Josh
That's what I was trying to figure out. I thought someone said use the o-ring for the oil drain plug but it was supposed to be for the block plugs. Thanks for clearing that up.
Originally Posted by Jarhead97
If you're using the Fumoto's for the oil drain plug and block drain plug replacements - why not just us the gasket that comes with the Fumoto's?
The gasket that comes on the Fumoto's is a flat seal made to seal oil drains. They weren't intended for the type of seal that the block plugs require which is why you install o-rings on them instead of a flat seal.
I think you just saved me some serious heartache down the road. Was going to do my flush in a few weeks and install the Fumoto's to replace the block plugs and I probably wouldn't have given it a second thought! Thanks
Anyone new coming to this thread please read the list on the first page as I am updating it as we come up with things to add. I believe at this point though we've about got it hammered out.
Alright, so at this point I have 2 bottles of CLR (approximately 2 quarts), 12 gallons of distilled water (1 distilled water flush and 4 to mix with coolant), 4 gallons of Final Charge, 2 Fumoto drain valves, 2 Motorcraft block drain plug o-rings, and 1 Motorcraft thermostat with seal. The other stuff will come after I've got a fresh cooling system with new coolant in it as I'm not experiencing any issues at this point but will be doing it at preventative maintenance.
Is there anything else I'm missing as far as maintenance, upgrades, or updated parts?
Good idea. I still think I'm gonna just do the inline filter going to the degas bottle as it will be cheap and effective. Has anyone used a fuel filter in that application or would you need a dedicate coolant filter?
